Mixing Wires - Electrical - DIY Chatroom Home Improvement Forum
Old 02-21-2011, 04:43 PM   #1
Rewards Points: 212
Question
mixing wires
is it code to mix wiring in circuits?
bluebird5 is offline   Reply With Quote
Old 02-21-2011, 04:53 PM   #2
Licensed electrician
Rewards Points: 1,296
Are you asking about mixing different sizes of conductors on the same circuit?
It is allowed but many consider it a poor practice as changes could be made at a later date that could create a hazard should someone install a larger breaker than the smallest conductor can handle.
Leah Frances (02-21-2011)
Old 02-21-2011, 05:03 PM   #3
Rewards Points: 212
yes different wire on the same circuit
Old 02-22-2011, 02:00 AM   #4
Scared Electrician
Saturday Cowboy's Avatar
you can always over size your wire(for a given breaker size) but never under size your wiring. the smallest size wire determines the circuit size(and thus the breaker size)
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 02-22-2011, 06:41 AM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,882
Yes it is, but WHY would you need to?? Rarely is there a truly valid reason.
D 3 number 12 wires equal one number 8 wire? Uncle Wayne Electrical 3 01-26-2011 09:00 PM
if there are red white green and black wires coming out of your walls like everywhere cray331 Electrical 3 01-17-2011 01:56 PM
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 08:07 PM
Removing wall with wires in it jboswald Electrical 11 11-29-2009 03:55 PM
Three hot wires coming into a receptacle? Jeff DIY Electrical 10 10-07-2009 02:35 PM
