-   -   mixing wires (http://www.diychatroom.com/f18/mixing-wires-96108/)
bluebird5 02-21-2011 03:43 PM
mixing wires
is it code to mix wiring in circuits?
Jim Port 02-21-2011 03:53 PM
Are you asking about mixing different sizes of conductors on the same circuit?
It is allowed but many consider it a poor practice as changes could be made at a later date that could create a hazard should someone install a larger breaker than the smallest conductor can handle.
bluebird5 02-21-2011 04:03 PM
yes different wire on the same circuit
Saturday Cowboy 02-22-2011 01:00 AM
you can always over size your wire(for a given breaker size) but never under size your wiring. the smallest size wire determines the circuit size(and thus the breaker size)
Speedy Petey 02-22-2011 05:41 AM
Yes it is, but WHY would you need to?? Rarely is there a truly valid reason.
