Old 10-17-2008, 04:27 PM   #1
Mixing NM and rmored cable
I need to run a wire to a light fixture in a finished ceiling where I know there are steel studs, self tapping screws, and air vent ducts(all bad for an NM cable). I think my best bet would be to run armored cable to the new light fixture. Power to the light switch is 14/2 NM. Whats the best way to make both types of cables work in a similar box? I plan to use a remodel style switch box as well as a remodel style light box.
n0c7 is offline   Reply With Quote
Old 10-17-2008, 04:34 PM   #2
You need a metal box for this one because ac/bx cannot go into a plastic box. Use a non metallic cable clamp for the nm and a bx type clamp with an anti-short (red head) bushing for the armored cable. other than that the wiring is the same. If the switch leg is nm then you can use a plastic box for that part of it. The hard part will be fastening the metal box into the ceiling. If there is a joist, strapping, or wood lathe in the ceiling then you can attach it to the wood with screws.
teamo is offline   Reply With Quote
Old 10-17-2008, 06:33 PM   #3
Electrician
They make metal and plastic round old work boxes.
chris75 is offline   Reply With Quote
Old 10-17-2008, 07:47 PM   #4
So will any metal workaround box work to fit the BX or do I need a specific box that accepts the various cable clamps? Just trying to visualize this as I'm only familiar with running NM cable and using the screw type clamps.
Old 10-17-2008, 08:10 PM   #5
Electrician
Being in the trade, I just swap out the straps if needed. But you must use the correct strap and box for the wiring method being used.
Old 10-20-2008, 01:27 AM   #6
I found the right romex ends as well as the BX(ac90) ends, and ended up with a metal conduit box which had 10 different knockout locations on it, and screw holes in various locations making it very easy to attach inside a finished ceiling. Thanks for the help, was an interesting fit.
One question on the BX though - I had trouble shoving those plastic red anti shorts into the cable. It seemed to be very difficult to get over the paper inside the cable. It took me a lot of effort. Does it matter if the anti short goes inside or on top of the paper inside the cable and how far should they insert into the cable?
