I am doing a bathroom remodel and have a 20 AMP circuit with only a single outlet and 12/2 wire. I have two other outlets that are already wired with 14/2 wire. I would like to put the outlets on the same circuit and wondering if it is okay to mix the 14/2 and 12/2 wires on the same circuit IF I swap out the breaker to a 15 AMP. I've calculated the load and the 15 AMP would be sufficient.
I know I could not mix in the 14/2 on teh 20 AMP circuit but I believe it is okay to mix them on the 15AMP.
you can run wire above code minimums without issue, but your capacity on the circuit is related to the smallest conductor on the circuit. Sounds like you have determined this is not an issue for you, and you might save a few bucks by using material you have in stock vs buy a new roll of wire when you only needed a few feet.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
