Mixed Wire Gauges Off Of A 20A Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 04-20-2011, 05:51 PM   #1
Mixed Wire Gauges off of a 20A Circuit
Alright... so I am rewiring a basement bathroom where I am making some improvements... it was a mess, hidden junction boxes in the ceiling, no covers, etc..
Anyway, the issue I have now is that I just moved the junction box to an accessible place and rewired everything (light over shower w/ switch, light over vanity w/ switch, fan with switch and then a feed to 3 outdoor outlets).
Here is my problem: After looking in the box and finding that this was a 20A circuit, I ran all new 12-2 romex to all fixtures from the junction box. When going to connect everything, it came to my attention that the wire to the breaker is 14-2 romex as is the wire going to the outdoor outlets, while the wire they had running to the outlet (GFCI) is 12-2. Access to running new 12-2 to the box will not be easy.
Do I:
A: Deal with the aggravation an run new 12-2 from the breaker to the junction box and from the junction box to the outdoor outlets (under a deck)?
B: Replace the 20A breaker with a 15A breaker, leave mixed wire. (Can 15A handle all of this?)
C: Leave it, its fine.(i know i know, but just throwing it out there in case I'm not nuts..)
THANK YOU SO MUCH IN ADVANCE!!!!
jfhanson4 is offline   Reply With Quote
Old 04-20-2011, 06:03 PM   #2
Mad Scientist
You're going to want to change that breaker to a 15A right away, and if it is indeed overloaded and trips often, start replacing wire with 12 gauge. Once you're sure all wire on the circuit is 12 gauge, put the 20A breaker back.
McSteve is offline   Reply With Quote
Old 04-20-2011, 06:07 PM   #3
McSteve -
Right now the breaker is off and the area is under construction. Would it be OK to leave it as a 15A breaker (if I were to change it)? Or should I just suck it up and run the 12-2?
Thanks so much for the reply!
Old 04-20-2011, 06:10 PM   #4
Scared Electrician
Saturday Cowboy's Avatar
A or b are your options.
if you don't mind that the outside plug only has 15a, then B is fine.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 04-20-2011, 06:46 PM   #5
That is what I thought. Thanks for the help!!
Tripping breakers,neutrals,120 volts and 240 volts OH My!!! Stubbie Electrical 17 06-11-2011 06:09 AM
14g Wire on 20 amp circuit dukes32 Electrical 3 12-02-2010 07:47 PM
change wire size in a circuit? mtmisfit Electrical 2 10-17-2010 01:07 PM
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 04:02 PM
Two Different Wire gages on Same Circuit OK? Lovegasoline Electrical 5 12-02-2009 05:00 PM
