Mixed Voltage Gang And Canadian Code (alberta Specifically) - Electrical - DIY Chatroom Home Improvement Forum
Old 09-29-2013, 11:13 AM   #1
Mixed voltage gang and Canadian code (alberta specifically)
I want to modify my current setup (as from builders) of a 3 gang high volt/ 1 gang low volt from 2 separate units (3+1 spaced quite far apart) to a single unit (4 gang).
I've found a gang from a USA vendor that does exactly what I want via a user settable internal partition that separates the high volt from the low volt
http://www.homedepot.com/p/Madison-E...MT4G/203343449
but I cannot seem to find a similar item here in Canada and I am beginning to wonder that if Canada in their infinite wisdom, said 'no no no - that makes too much sense and we won't allow you to use that here in Canada'.
what does Canadian code state regarding mixed voltage gangs?
BMcN is offline   Reply With Quote
