Mixed Up Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 05-31-2012, 04:40 PM   #1
Unhappy
mixed up wiring
I was asked by a friend to install two light fixtures in his house and did not say much of anything thing else. When I showed up every thing seemed to be normal. As doing the procedure of cutting power nothing was marked.
And the search began, found the right breaker and undid the first light. found out the light box has three runs of wire 2-14/2's and one 14/3 and the problem is the connecvtion is only a single switch and so I think.
the second light I also found out is the same thing.
I need some help.
handimike is offline   Reply With Quote
Old 05-31-2012, 04:50 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
I need some help.
Why do you need help? Just hook the new lights up to the wires you removed from the existing fixture.
Old 05-31-2012, 05:08 PM   #3
mixed up wiring
the thing is the lights did not work before I started and the guy thought that the fixtures were broken.
Old 05-31-2012, 06:51 PM   #4
E2 Electrician
Best I can tell you is to map out the wires and see if you can make it work to how your buddy would like it to work.
Old 05-31-2012, 06:58 PM   #5
joed's Avatar
Rewards Points: 13,742
You need to map where the cables go. We can't do much to help without the cable info.
Tags
lighting problem interior
Help with wiring issues on a newly purchased house ThatGuy Electrical 13 01-17-2012 10:51 AM
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 09:01 AM
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 09:46 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
