Mixed Gauge Wire On 15 Amp Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 07-03-2010, 02:10 PM   #1
mixed gauge wire on 15 amp circuit
During a recent ceiling fan installation, I noticed that the electrician whom I hired to install a subpanel moved a 15 amp circuit onto a 20 amp breaker (I noticed since it's the circuit I had to turn off to install the fan. I know it used to be on a 15 amp breaker because I had carefully mapped all the circuits a few years previously). I am guessing that the electrician did this because the first leg of that circuit coming out of the breaker box to an outlet on a stairwell is 12 gauge wire, and as far as I can tell from routing about in the attic and inspecting the outlets the remainder of the wires on the circuit are 14 gauge. Certainly all the receptacles are 15 amps. I know for sure that I need to get the circuit back onto a 15 amp breaker, but what I am not certain about is whether I need to get that first leg of 12 gauge wire replaced with 14 gauge as well. The first outlet has a 12 gauge wire coming in and a 14 gauge going out.
Also, I am wondering whether I should have that electrician come back and make the switch and if it is reasonable to expect that he shouldn't charge me for that (meaning, was it a reasonable or an unreasonable mistake on his part)? Thanks for any advice.
GretaDIY is offline   Reply With Quote
Old 07-03-2010, 02:29 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
deleted
Disclaimer
& Stay Safe
.....Bob Lavery
Old 07-03-2010, 02:39 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
You do not have to replace the #12 wire with #14. The rule is you cannot use anything smaller than #12 on a 20 amp breaker and #14 on a 15 amp breaker. You can use as large wire as you want.
In fact, larger wire is often used to overcome what is called voltage drop or voltage loss due to a long distance the circuit is run. Wire is resistive and the longer it is, the more resistance it will have. That causes voltage loss as the resistance adds. Larger wire has a lower resistance so often times, a larger wire is used to prevent those voltage losses.
and if it is a simple swap, yes, I would expect the electrician to do it for free. What he did actually makes your house not meet "code". If there is no way to simply swap it to another 15 amp circuit and you would need another breaker or subpanel, then he could rightfully charge you for that additional work.
The Following User Says Thank You to nap For This Useful Post:
GretaDIY (07-03-2010)
Old 07-03-2010, 03:07 PM   #4
Thank you
Thank you for the concise and helpful post. From all I have read it seemed logical to be able to use a larger wire, but truly there is a lot of conflicting information on the internet about the question of mixing them. It seems that the reasoning of those against it tends to be more related to the danger of having someone later on misinterpret the capacity of the circuit and make the mistake that my electrician did. Perhaps they have a point.
Anyway, based on your input I will stop fretting about that leg of wire :-).
Old 07-03-2010, 03:20 PM   #5
nap
You talking to me?
nap's Avatar
they do have a point as it can easily happen, just as it did with you.
How to wire three switches on one circuit Abs777 Electrical 12 03-25-2010 03:15 PM
Lights on circuit with outlets Klawman Electrical 16 02-22-2010 06:51 AM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Where to wire in to circuit brackh Electrical 5 02-28-2008 06:04 AM
12 gauge wire to 14 gauge on an outlet question diyer4162 Electrical 35 12-20-2007 12:55 PM
