Old 08-27-2011, 10:53 PM   #1
Question
Mitsubishi ws-55511 error 22
I replaced the stk 393-110 IC chip and the tv worked perfect for a day and a half... then... it shut off and would not come on. This is when I started getting the error code 22. I then replace the two 5 amp pico fuses f9a04 and f9a05 and it didn't fix the problem. I have since read that I should have replaced the power caps but am also reading that a closer match to my problem is the IC chip agaim. I used a generic chip and did not insist on the "sanyo" chip. Is there and educated opinion out there as to whether the cheaper chip is my problem or should I look elsewhere? Any appropriate help would be aprreciated. Thanks!!!
jonesy is offline   Reply With Quote
Old 08-27-2011, 11:09 PM   #2
Code05's Avatar
There may be a electronic tech or similar here, but in general I would say this is a residential wiring and repair section of this forum.
Code05 is offline   Reply With Quote
Old 08-28-2011, 02:41 AM   #3
Thadius856's Avatar
I would imagine that you need to check the power ballast appeared to be intact before even touching the IC for an Error 22 (short protect).
A little Google'ing resulted in the following series:
- Check horizontal output transistor
- Check diodes on horizontal sweet connection circuit
- Check power supply
- Check ICs on convergence board
- Check DM board (3300 mfd @ 16v)
Good luck.
Thadius856 is offline   Reply With Quote
Tags
error code 22, mitsubishi ws-55511
Mitsubishi ductless vs. central air rrtom HVAC 4 07-13-2011 11:23 PM
Mitsubishi MSH12TN indoor unit Mike2401 HVAC 0 11-03-2010 09:03 PM
removing Mitsubishi 92 Galant factory spoiler manuleka Automotive Repairs 1 09-15-2009 11:24 AM
Anyone know about ductless AC systems like the Mitsubishi Mr Slim? jayp HVAC 3 06-19-2009 10:50 AM
'98 Mitsubishi Galant Sliver Automotive Repairs 6 12-26-2008 09:12 PM
