Miswired Wall Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 05-06-2008, 03:14 AM   #1
Miswired wall outlets
i have 3 bedroom wall outlets that are part of a circuit that also includes a bathroom. the 1st outlet wiring includes - 2 white, 3 black and a ground. the 2nd outlet includes 2 white, 2 black and a ground. the 3rd outlet includes 1 white, 1 black and a ground. .... i am doing something wrong with the 1st outlet , as i can't seem to get these to work .... any suggestions on the correct wiring for the 1st outlet? help !!
JAL1553 is offline   Reply With Quote
Old 05-06-2008, 06:32 AM   #2
Licensed Pro
According to you count, you're missing a wire at the first outlet. If you have three blacks, you should have three whites.
Old 05-06-2008, 08:26 AM   #3
RippySkippy's Avatar
agree with HH...make sure when you count wires not to confuse singles with those that may be pigtailed.
RippySkippy is offline   Reply With Quote
Old 05-06-2008, 12:32 PM   #4
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
Could be that the first receptacle is half switched. One black would come from a switch and connect to 1/2 of the first receptacle, with the tab broke out. The other 2 blacks would be your line in and out to the next receptacle. They would be pigtailed and connected to the other 1/2 of the first receptacle. The whites are in and out. At the 2nd receptacle you have the blacks and whites in and out. At the third, you just have the line in.
The trick is to find the switched black at the first receptacle if my guess is correct.
John
jrclen is offline   Reply With Quote
Old 05-06-2008, 01:02 PM   #5
joed's Avatar
Rewards Points: 11,990
Wire come in sets. If you have 3 black then you should have three white and three ground. Find the missing white in the first receptacle. Connect it with the other whites and everything down stream will probably work.
Old 05-06-2008, 08:15 PM   #6
jrclen's Avatar
Rewards Points: 514
Haven't you ever run across a box where the home owner/handyman just cut off the white and ground flush because he only needed a black switch leg? I've seen that many times.
Not that you are wrong on this one, you might be 100% correct. It would be easy enough to look.
John
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 02:39 PM
