-   -   Miswired wall outlets (http://www.diychatroom.com/f18/miswired-wall-outlets-20672/)
JAL1553 05-06-2008 02:14 AM
i have 3 bedroom wall outlets that are part of a circuit that also includes a bathroom. the 1st outlet wiring includes - 2 white, 3 black and a ground. the 2nd outlet includes 2 white, 2 black and a ground. the 3rd outlet includes 1 white, 1 black and a ground. .... i am doing something wrong with the 1st outlet , as i can't seem to get these to work .... any suggestions on the correct wiring for the 1st outlet? help !!
HouseHelper 05-06-2008 05:32 AM
According to you count, you're missing a wire at the first outlet. If you have three blacks, you should have three whites.
RippySkippy 05-06-2008 07:26 AM
agree with HH...make sure when you count wires not to confuse singles with those that may be pigtailed.
jrclen 05-06-2008 11:32 AM
Could be that the first receptacle is half switched. One black would come from a switch and connect to 1/2 of the first receptacle, with the tab broke out. The other 2 blacks would be your line in and out to the next receptacle. They would be pigtailed and connected to the other 1/2 of the first receptacle. The whites are in and out. At the 2nd receptacle you have the blacks and whites in and out. At the third, you just have the line in.
The trick is to find the switched black at the first receptacle if my guess is correct.
joed 05-06-2008 12:02 PM
Wire come in sets. If you have 3 black then you should have three white and three ground. Find the missing white in the first receptacle. Connect it with the other whites and everything down stream will probably work.
jrclen 05-06-2008 07:15 PM
Haven't you ever run across a box where the home owner/handyman just cut off the white and ground flush because he only needed a black switch leg? I've seen that many times.
Not that you are wrong on this one, you might be 100% correct. It would be easy enough to look. :thumbsup:
