Missing Outlet Box - Electrical - DIY Chatroom Home Improvement Forum
Old 01-23-2010, 09:39 PM   #1
Missing outlet box
Hey y'all,
I'm working on a bathroom project which includes replacing the light fixture to something a little less... well.. ugly. Unfortunately it seems that no outlet box was placed in the wall. To make matters worse, there is a water pipe on the right side of the opening. Now I would have liked to put a fixture that was not a bar type but not sure if I have any other options at this point. Any advice would be great.
billybobjoe is offline   Reply With Quote
Old 01-24-2010, 07:34 AM   #2
Depending on the fixture, a surface-mount box may work for you.
oberkc is offline   Reply With Quote
Old 01-24-2010, 08:43 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,228
Not all fixtures require separate boxes. Some fixtures have integrated boxes to enclose the cable and fixture wires.
Coastal South Carolina
Old 01-24-2010, 03:01 PM   #4
Thanks for the replies. I guess I need to take a closer look at my lighting options to see all that is out there.
Old 01-24-2010, 04:51 PM   #5
Master Electrician
richgriffith's Avatar
is the hole dead center of the vanity or can you move alittle to the left? if you can move alittle to the left you can use a round old work cut in box.
richgriffith is offline   Reply With Quote
Old 01-24-2010, 07:52 PM   #6
Master Electrician
put in a cut in box
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 03:36 PM
What did i do wrong? - Outlet install trips breaker nymex Electrical 22 05-07-2009 02:44 PM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 09:05 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 03:59 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 08:45 AM
