Minimum Width For A Piece Between Two Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 10-21-2012, 08:18 PM   #1
Rewards Points: 1,062
Question
minimum width for a piece between two outlets
i was wondering if there is a minimum suggested width for a piece of drywall that spans between two adjacent power outlets (one for power, other for cable). i was thinking of putting two outlets on each side of a stud at the same hight, which would mean the piece of drywall in between would be just over 1.5" -- i thought that's two narrow, i.e. could easily break or get shredded when putting screws so i doubled up the stud to get more width.
is there a norm for a minimum width of a drywall strip?
thanks
Old 10-21-2012, 10:59 PM   #2
no there isn't . ive seen the same situation you have many times in new construction. it sucks when there is a seam there tho. pain in the ass to mud it. cut it a little less then 1-1/2 inches or it will hit one of the boxes and break it.
Old 10-21-2012, 11:06 PM   #3
Rewards Points: 13,458
Use a box like this then there's no spacing needed.
http://www.amazon.com/Arlington-TVBU.../ref=pd_cp_e_0
They also sell a simple devider that just slips into plastic outlet box for around $1.00.
Old 10-22-2012, 07:59 AM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
You have to use the divider to separate the TV cable from the 110V. Low voltage wires canot share the same box with the 110V without it.
New Home: 2 Prong Outlets & K&T Wiring (Maybe) weekley14 Electrical 4 05-29-2012 07:56 AM
Minimum distance from floor to bottom of baseborad heat outlets Romeo100 HVAC 2 05-17-2012 04:50 PM
Changed Outlets...Lights stay on... agentphish Electrical 4 03-29-2012 09:02 AM
Several outlets and lights on a circuit are not functioning, while others are fine. mrdojo Electrical 12 03-26-2012 06:23 PM
Power leading to outlets but no power ? s_anthony Electrical 22 01-05-2009 01:08 PM
