Old 02-29-2008, 10:14 AM   #1
Beer Advocate
Taipans's Avatar
Minimum outlet height?
Is there a minimum outlet height for basements? I can't find anything code wise outside of distance apart?
Taipans is offline   Reply With Quote
Old 02-29-2008, 10:32 AM   #2
Crabby Bastard
terri_and_jj's Avatar
i have never seen a height requirement specific to a basement. The common practice is to simply make them as high or higher than the ones in the rest of the house. Most codes deal with distance from each other, like you mentioned
terri_and_jj is offline   Reply With Quote
Old 02-29-2008, 10:40 AM   #3
Beer Advocate
Taipans's Avatar
Thats what I was thinking. My father was dumbfounded when I told him I didnt see a code for height. So I wanted to double check with you guys! And I was going to copy the rest of the house anyways but just wanted to make sure there wasn't something I was missing!
Old 02-29-2008, 11:00 AM   #4
Crabby Bastard
it never hurts to set them higher than rest of the house,
i would go AT LEAST 18"
Old 02-29-2008, 04:20 PM   #5
Custom Cabinet Maker
16 Oz Stanley hammer off floor to bottom of box :}:}} seems to be the "norm" around here :}
skymaster is offline   Reply With Quote
Old 02-29-2008, 04:23 PM   #6
Beer Advocate
Taipans's Avatar
I am a newb when it comes to construction and have no excelled to that level of skill yet... lol
Old 02-29-2008, 06:05 PM   #7
Handyman
I generally use 14" from concrete base here
canadaclub is offline   Reply With Quote
Old 02-29-2008, 07:13 PM   #8
Licensed Electrical Cont.
Speedy Petey's Avatar
Well Norm don't work here.
Old 02-29-2008, 07:33 PM   #9
joed's Avatar
The only height restriction if you put them too high you can't count them as part of the required receptacles along a a wall.
Old 02-29-2008, 07:38 PM   #10
Crabby Bastard
isn't the height that is too high like 6' or more?
Old 02-29-2008, 10:36 PM   #11
joed's Avatar
Yes they must be below 5.5 feet. They can be in the floor if you wish as long as they are within 18 inches of the wall they can be counted as part of the required receptacles.
Old 02-29-2008, 11:03 PM   #12
Electrician
Most of the houses I do end up in the baseboard... go figure.
chris75 is offline   Reply With Quote
Old 02-29-2008, 11:38 PM   #13
Speedy; ya sound a tad cranky LOL LOL I will have Norm send his "special Estwing outlet height measuring device" sent to ya :}:}:}:}
Old 03-01-2008, 07:51 AM   #14
Well Sky if you knew me you'd know I was always either cranky or cantankerous. I've been banned from worse boards than this for such an immoral attitude.
I just laugh when in today's world guy are still using "hammer height". Either you work alone, or buy all your guys all the same hammer, or just don't care if all the receptacles are exactly the same.
Put it this way, I bought a rotary laser just to make sure the receptacles in big kitchens are EXACTLY the same.
Old 03-01-2008, 04:05 PM   #15
Licensed Electrician
jrclen's Avatar
Does the Canadian code have required receptacle spacing along a basement wall?
jrclen is offline   Reply With Quote
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 10:05 PM
Minimum Deck height? sandyman720 Building & Construction 16 01-30-2008 12:12 AM
minimum window height mt232 Building & Construction 7 03-24-2007 02:10 AM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 09:45 AM
