Old 10-19-2005, 04:23 PM   #1
minimum impact switchbox
I'm adding an outlet or two to my garage for my new workshop. The garage was finished by a former owner, who evidently didn't need more than the measly one 15a outlet. I have easy access to the top of the wall so can drop down the cable.
Just wondering if there is a switchbox available that secures from inside the box so I can limit my wall-cutting to just enough to get the switchbox through the hole?
sherlock is offline   Reply With Quote
Old 10-19-2005, 04:26 PM   #2
Also, I'll be adding a dedicated circuit for these outlets. Do I need a permit before or an inspection after completion?
Old 10-20-2005, 01:25 AM   #3
renovations
Yeah, there are all kinds of boxes. I like using the ones with interior clamps 'cos I do renovations and it makes life easier for the next guy. You can get them where they have the ability to simply attach to the drywall, if you need to put one where there isn't a stud right there too.
I don't know about permits in your area, but I would assume you need a permit before and an inspection after. Good luck.
Bonus is offline   Reply With Quote
Old 10-20-2005, 02:01 PM   #4
Bonus,
Can you tell me where to get them. Can't find listed at Home Depot or Lowe's.
Thks
Old 10-20-2005, 04:26 PM   #5
Electrical Contractor
Are you coming down inside the walls or on the outside of the sheetrock? Bouns is talking about old work boxes. They come in single and double gang. They have 2 ears that tighten against the sheetrock from the back side. They have them at Lowes, HD, hardware stores.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 10-20-2005, 07:34 PM   #6
Contractor
I use them all of the time, they have little 'ears' that swing out and secure them to the drywall.
An older wall, with firestops, can really challenge the installation.
Teetorbilt is offline   Reply With Quote
minimum window height mt232 Building & Construction 7 03-24-2007 02:10 AM
2 curcuits in 2-gang switchbox hockeyfan33 Electrical 6 02-20-2007 12:27 AM
Minimum Fall Bill46 Plumbing 3 08-29-2006 10:00 AM
Makita Impact Driver vs Wrench HELP! the496rocket Tools 8 02-14-2006 08:41 PM
Minimum Clearance to Vent Inside Wall? MikeinBurien Plumbing 12 12-06-2005 12:03 AM
