Minimum Clearance? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-25-2013, 02:04 PM   #1
Minimum clearance?
Is there a minimum clearance from the ground a LB connector has to be when turning into the house? I'm running conduit along the bottom edge of the siding,then turning into the house about 1 foot from the landscape. Is this ok?
Thanks for your help!
redtail627 is offline   Reply With Quote
Old 11-25-2013, 02:08 PM   #2
Rewards Points: 12,856
That's more then enough.
Old 11-25-2013, 02:28 PM   #3
Thanks Joe....In Minnesota
Old 11-25-2013, 02:44 PM   #4
iminaquagmire's Avatar
Rewards Points: 338
Make sure you're using listed connectors for outdoor use. IE raintight connectors if you're using EMT.
iminaquagmire is offline   Reply With Quote
Old 11-25-2013, 06:06 PM   #5
Another LB clearance question
I'm in Ontario. I have to run wire from the hydro meter outside the garage under concrete floor into the service panel in the mechanical room. In order to get the line low enouch to be under the concrete as required by code the LB fitting outside ends up below grade. What can I do? Is there a different fitting that can be below grade or can I cover the LB fitting in concrete before it enters the house?
Please help asap.
lehmjoe is offline   Reply With Quote
Old 11-25-2013, 08:21 PM   #6
joed's Avatar
Rewards Points: 11,582
LB can not be buried. Use a long sweep elbow.
Old 11-25-2013, 08:42 PM   #7
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Why do people start two threads when they don't like what they are told in another?
Old 11-26-2013, 09:31 AM   #8
If you're referring to me. I posted my question first in someone's elses' thread and then thought I should start a new thread as the other one was quite old. This is my first time using this forum. So, if you're an expert perhaps you can be patient with a newcomer?
Range hood clearance to top of gas range less than minimum joemc3 Appliances 9 02-28-2013 02:42 AM
Mini Can light Clearance BigJim Electrical 4 02-01-2013 11:57 AM
Clearance for double oven installation Steeler99 Building & Construction 1 01-30-2011 06:16 PM
Furnace Clearance avtck HVAC 0 01-02-2010 10:13 PM
Minimum Clearance to Vent Inside Wall? MikeinBurien Plumbing 12 12-06-2005 12:03 AM
