Minimum Amperage - Electrical - DIY Chatroom Home Improvement Forum
Old 08-17-2011, 11:29 AM   #1
Minimum amperage
I need to know the minimum service amperage required by law for a home. I am thinking of building an off the grid home and need to know minimum requirements for solar and wind incorporation.
PJB54 is offline   Reply With Quote
Old 08-17-2011, 11:39 AM   #2
Licensed electrician
Rewards Points: 1,038
The NEC requires a minimum service size of 100 amps for a dwelling.
PJB54 (08-29-2011)
Old 08-17-2011, 12:06 PM   #3
Rewards Points: 6,652
http://www.energystar.gov/index.cfm?...edits.tx_index
The Following User Says Thank You to gregzoll For This Useful Post:
PJB54 (08-29-2011)
Old 08-17-2011, 01:43 PM   #4
Semi-Pro Electro-Geek
Rewards Points: 2,860
An off-grid project will play by different rules. You will generally not be required to comply with minimum service ampacity or load calculation rules. Sometimes this requires officially requesting a variance from the building department, other times it's a completely informal process. Regardless, you won't be delivering 100A service on a solar system.
mpoulton is offline   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
PJB54 (08-29-2011)
Old 08-17-2011, 02:58 PM   #5
joed's Avatar
Rewards Points: 11,598
Most insurance companies will not insure a house with less than 100 amp service.
The Following User Says Thank You to joed For This Useful Post:
PJB54 (08-29-2011)
Old 08-17-2011, 05:14 PM   #6
I=E/R
a7ecorsair's Avatar
You may want to consider making it code compliant just in case at some point it has to go on the grid.
a7ecorsair is offline   Reply With Quote
The Following User Says Thank You to a7ecorsair For This Useful Post:
PJB54 (08-29-2011)
meter vs. sum of circuit amperage amakarevic Electrical 5 07-13-2011 05:56 PM
concrete block detached building, minimum space between openings rich624 Building & Construction 2 11-22-2010 08:48 PM
Dual Pole Breaker Amperage Question jcwilshire Electrical 2 11-22-2010 01:45 PM
How do panels get their amperage rating? Randell Tarin Electrical 14 01-23-2008 07:10 PM
Minimum Insulation Requirements? sandyman720 Building & Construction 4 08-19-2007 10:07 PM
