Mini Split AC Hook Up - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 03-21-2014, 04:00 PM   #31
Rewards Points: 770
i also have a 120v unit, indoor part is at 32v!
carmusic is offline   Reply With Quote
Old 03-22-2014, 12:57 PM   #32
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
And what is your point? You still have to follow the NEC.
Old 03-22-2014, 06:07 PM   #33
Rewards Points: 1,989
No matter what the schematic that you came up with says , many / most of ours are low voltage between the inside & outside unit . Same as tstat wiring between a furnace and a tstat .
I do not know what is SOP in your location , tstat cable is run " wild " here . And , evidently , other places , too ?
God bless
Wyr
WyrTwister is offline   Reply With Quote
Old 03-22-2014, 06:10 PM   #34
E2 Electrician
Originally Posted by WyrTwister
No matter what the schematic that you came up with says , many / most of ours are low voltage between the inside & outside unit . Same as tstat wiring between a furnace and a tstat . I do not know what is SOP in your location , tstat cable is run " wild " here . And , evidently , other places , too ? God bless Wyr
I'm betting they are not low voltage, I'm betting you are mis reading the schematic, and by the looks of your unit, you are mis informed.
Old 03-22-2014, 08:49 PM   #35
Well , I got off the sofa and my lazy behind . Went out to the truck and got my Fluke & a screwdriver . Got up on a chair & proceeded to check the voltage , at the terminal strip , where the interconnecting plenum cable is terminated at the inside unit .
Different terminals yielded different voltage between them . The first 2 are probably the low voltage " power " I got 29 - 32 volts . Did not bother to notice if it was AC or DC , I did not really care . The other readings were less than that to zero .
We use that particular plenum cable , 2 pair T/S cable for energy management . Brought about 25' from work . Seems to work fine .
There is nothing more that I can think to add ?
God bless
Wyr
Old 03-22-2014, 09:36 PM   #36
E2 Electrician
Well , I got off the sofa and my lazy behind . Went out to the truck and got my Fluke & a screwdriver . Got up on a chair & proceeded to check the voltage , at the terminal strip , where the interconnecting plenum cable is terminated at the inside unit . Different terminals yielded different voltage between them . The first 2 are probably the low voltage " power " I got 29 - 32 volts . Did not bother to notice if it was AC or DC , I did not really care . The other readings were less than that to zero . We use that particular plenum cable , 2 pair T/S cable for energy management . Brought about 25' from work . Seems to work fine . There is nothing more that I can think to add ? God bless Wyr
And? What's your point?
Old 03-23-2014, 04:17 AM   #37
Mine is low voltage . Many / most of these units are . "
Low voltage " cable is fine . ( Although , I think the cable I used is rated for 300 volts ? )
My 120 VAC is run in Romex . Where it exits the vertical " cover " , it is inside LiquidTite flex . To the pull no-fuse disconnect and from there to the condenser .
As is the plenum cable , in a separate flex .
Have a fine day .
God bless
Wyr
Old 03-23-2014, 05:29 AM   #38
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,228
Have a fine day .
God bless
Wyr
NMB in Sealtite in a wet or damp location is non compliant.
Coastal South Carolina
Mini split vs. duct-based systems - venting? sheslostcontrol HVAC 3 06-07-2015 04:15 PM
Mini split AC 120 or 240 - lsu181hsv model amb1s1 Electrical 5 08-06-2013 05:01 AM
Mini split in basement? Mills314 HVAC 1 07-04-2011 09:36 AM
mini split BTU question... newbieowner HVAC 13 05-31-2011 09:57 PM
Installing a mini split ductless system agenkin HVAC 1 06-14-2008 09:33 PM
