Old 07-19-2007, 09:37 AM   #1
Mini refrigerator wattage?
I'm trying to determine how much wattage a mini-refrigerator uses. Here's the specific model I'm interested I'd like to get: http://products.geappliances.com/App...SCS&SITEID=GEA
Unfortunately, GE, and most other manufacturers, don't list this information. They do show their energy guide however, which states that this product consumes 345 kWh a year.
kcrossley2 is offline   Reply With Quote
Old 07-19-2007, 12:59 PM   #2
Extreme DIY'r Adk's, NY
Guesstimate....
I have seen current draw of a full size refrigerators ballparked for calculations at 425 watts which would be 3.7 amps, for compressor start up add 70%, so another 300 watts for a total of 725 watts max or 6.3 amps. A smaller unit would obviously be some amount less but a compressor is a compressor so I imagine it could still be 5 amps max.
If you can find one in a store you can get better info off the tag on the back too.
crecore is offline   Reply With Quote
Old 07-19-2007, 01:09 PM   #3
Thanks, I did. It's 145W, which is a lot lower than I expected.
Old 07-19-2007, 01:09 PM   #4
Agent 000
SecretSquirrel's Avatar
Yeah, that is a bummer. I'm not quite sure why they don't do that. I noticed Home Depot has these units. If there's one close by, you could sneak a peak at the nameplate or... call the GE 800 number and tell them you gotta have that info.
SecretSquirrel is offline   Reply With Quote
Old 10-20-2008, 06:14 AM   #5
Technoir1
KW/H = Watts x Hours/1000
so 345 = W x 8640/1000
so W x 8640 = 345 x 1000
so W = 345,000 / 8640
W = 39.9305 Watts
which by the way would not be possible for a minifridge running on mains power as the low wattage of 39 watts is unheard of and impossibile. unless it's mayby a 12volt minature one capable of holdin a single beer
I know its an old thread but I hope it heps somebody
another formula to find Power (P) measured in watts is P = V x I meaning power in watts = Volts x Amps
Or another to find KW/h is..... V x I x Hours /60
technoir1 is offline   Reply With Quote
Old 10-20-2008, 11:26 AM   #6
DIY'r
ScottR's Avatar
W = 39.9305 Watts
You've assumed the load will be constant. The compressor, defroster, light, etc, will be engaged intermittently.
ScottR is offline   Reply With Quote
Old 10-20-2008, 01:07 PM   #7
Sort of the same point as the poster above me, but you've also assumed constant usage.
I don't know the formula they use for those energy star ratings but I'm sure it's not full load consumption for 8640 hours (every minute of an entire year).
I've also gone looking for mini fridge current draw - trying to decide if I want to put a dedicated circuit in for a mini fridge. I came up empty too. I'm glad someone in this thread had a number (145w)...definately helps my decision.
Garasaki is offline   Reply With Quote
Old 10-20-2008, 05:26 PM   #8
Technoir1
lol how silly of me! you are absolutely correct
Old 04-16-2010, 04:06 AM   #9
TRY THIS, AS A START...
http://www.ftc.gov/bcp/conline/edcam...ndef_brand.pdf
ITS MY UNDERSTANDING THAT TO GET YOUR CONSUMPTION...PER THE GOVT INFO PROVIDED
YOU TAKE THE ANNUAL POWER CONSUMPTION DIVIDE BY 365 THEN TAKE THAT 'RESULT'
AND DIVIDE BY 24... FOR A REAL SIMPLE, BALL PARK, HOURLY POWER CONSUMPTION FROM A KWA NUMBER.
NOW, YOU CAN COMPLICATE THIS WITH ALL SORTS OF BELLS, WHISTLES AND ASSORTED SITUATIONS HAPPENING,
BUT IT IS THE 'GOV'T.S' NUMBERS... AND WE ALL KNOW WE CAN TRUST THEM TO RUN THINGS... LIKE MINI FRIDGES!
IVE FOUND INFO ON USING CHEST FREEZERS AS FRIDGES...PRETTY SIMPLE!
ALOHA
PUNADUDE is offline   Reply With Quote
mini van v6 Darylh Automotive Repairs 15 03-04-2007 11:52 PM
mini fridge thermostat problems furniture_guy Appliances 1 12-19-2006 07:55 AM
Mini Air Conditioner bwoo HVAC 7 12-17-2006 01:38 PM
Rod Lengths for Ceiling Fans and Mini Pendants Not Sure Electrical 6 10-25-2006 12:23 AM
