Mild Zap - Electrical - DIY Chatroom Home Improvement Forum
Old 01-17-2011, 10:52 AM   #1
Mild zap
I have a little PA System, and a guitar amp in my old house. The PA is plugged into one circuit, and the amp into another. When I turned them both on, I got a bit of a mild shock sensation from the microphone connected to the PA when I played the guitar thru the amp. I decided to test the outlets. One is wired/grounded correctly (PA/Mic) the other (guitar/amp) has hot and neutral reversed. I'll change it, but if this is the cause, is there potential for bigger a shock?
Ontareo is offline   Reply With Quote
Old 01-17-2011, 11:52 AM   #2
I=E/R
a7ecorsair's Avatar
Do both the PA and Amp have a three prong power cord? Are both receptacles on the same circuit / circuit breaker?
Remove power to the receptacles and pull them out an inspect the connections and make sure there is a ground wire connect to the ground screw on each receptacle.
a7ecorsair is offline   Reply With Quote
Old 01-17-2011, 03:36 PM   #3
I'll pull it apart and check it out. I was just wondering if using a PA/microphone plugged into a correctly wired outlet, and holding a guitar plugged into a different and incorrectly wired outlet might produce some potentially odd electrical flow .
Old 01-17-2011, 04:16 PM   #4
I=E/R
a7ecorsair's Avatar
If you are getting a tingle something is wrong somewhere. You didn't answer my question about the power plug - do both have a three prong power cord?
Old 01-17-2011, 04:22 PM   #5
3 prong, to be sure. PA is correct and grounded, other plug (guitar amp)is for sure hot/neut. reversed, and grounding is what I'm going to check into.
Old 01-18-2011, 12:54 AM   #6
Scared Electrician
Saturday Cowboy's Avatar
yep now you know why they must be wired correctly
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Very mild shock when I flip my light switch. Jessica B. Electrical 2 11-22-2010 07:53 AM
One brown thumb and some mild ambition! cellophane Gardening Forum 4 05-03-2010 11:20 AM
damp basement wall. itguru Building & Construction 7 12-16-2007 05:02 PM
