Middle Of The Run Double Duplex - Electrical - DIY Chatroom Home Improvement Forum
Old 08-03-2012, 08:17 PM   #1
Rewards Points: 119
Middle of the run double duplex
Hi,
I have a middle of the run duplex receptacle that I have transformed in a double duplex.
Black to brass, white to silver and I two jumps to add the second duplex. Of course, I have the bare ground on both green screws connected to the double gang.
Measuring:
If I measure with an analog multi meter tester, I get 120V on all 4 sockets.
If I measure with a non touch voltage tester, I get sound in the black, but also in the neutral (if the bare is disconnected), if the bare is connected the neutral does no longer sound.
On the same circuit I have a duplex receptacle, I did the same experiment, with or without bare ground connected, the neutral does not sound (which looks more normal to me).
What am I missing??
Thanks guys
Alex
Metallo is offline   Reply With Quote
Old 08-03-2012, 08:39 PM   #2
Missouri Bound's Avatar
Originally Posted by Metallo View Post
Hi,
What am I missing??
Nothing. You expect too much from a non-contact tester. Proximity is everything with non-contact testers. Run that tester through your hair and it will register voltage.
Do you want it your way or the right way?
Old 08-03-2012, 08:51 PM   #3
"So I Re-Wired It"
MisterZ's Avatar
those no-contact testers are unreliable.
with the outlet wired together, Black probe on ground and Red probe on Brass screw (or small outlet slot if assembled)
the volt meter should get between 115v-120v depending on your service.
Now with the Black probe on ground and Red probe on Silver screw (or wide slot on outlet) the reading should be minimal.
if you get 120v on the neutral, something is wrong.
DO NOT rely on the no-contact probes
or get a $3 polarity tester like this...
Knowledge is Power, but 240v can Keel You!!
MisterZ is offline   Reply With Quote
Old 08-03-2012, 09:23 PM   #4
Rewards Points: 119
First reading gives me 120V
Second reading gives me no voltage
Consider that my multi tester is analog.
Hope this is good.
Thanks!
Alex
Old 08-03-2012, 11:17 PM   #5
"So I Re-Wired It"
MisterZ's Avatar
i think you're OK here
Split receptacles, double pole breakers and multiple circuits in a junction box. morganhammer Electrical 6 04-05-2011 04:38 PM
double pole thermostat for kickspace heater lee12 Electrical 3 12-09-2010 12:52 PM
Double Hung vs Single Hung CZSteve Remodeling 0 11-08-2010 07:29 AM
Increase to double gang boxes... jamiedolan Electrical 20 10-17-2008 12:21 PM
What do you think about Double Glazing with plastic sheets? foster01 General DIY Discussions 1 08-25-2008 04:12 PM
