Middle Of Circuit Switch - Is This Possible? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-12-2011, 09:50 AM   #1
Middle of Circuit Switch - Is This Possible?
All of the diagrams I've seen show the power source entering the light box as well as leaving the light box to power receptacles downstream. Example here: http://www.indepthinfo.com/wire-swit...choutlet.shtml
My question: Is there a way to have the power source enter the switch instead of the light box, and I could still power receptacles downstream? If so, does the power have to leave the light box, or can it all come in and leave from the switch? Any links to a diagram would be very much appreciated.
Thanks!
PJ33P is offline   Reply With Quote
Old 02-12-2011, 09:55 AM   #2
joed's Avatar
Rewards Points: 12,332
All of the above are possible.
Old 02-12-2011, 10:08 AM   #3
Thanks, so I assume it's as simple as this - assuming I want power to both enter and leave through the switch:
In the switch box:
Connect all whites together (source, light, downstream receptacle) with wire nut.
Connect the supply black and the downstream receptacle black together and to one of the switch terminals.
Connect the light black to the other switch terminal.
Connect all grounds together (source, downstream, light, if it has one).
Old 02-12-2011, 12:54 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 380
In the switch box:
Thats it!
The Following User Says Thank You to jbfan For This Useful Post:
PJ33P (02-12-2011)
Old 02-12-2011, 05:21 PM   #5
Thank you!
Single Pole Switch is "Hot" to the Touch mbaudler Electrical 7 12-15-2010 11:28 AM
20 amp switch on 15 amp circuit Mike L Electrical 2 07-29-2010 06:07 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
Adding 15 amp light and switch on a 20 amp circuit Jzack26 Electrical 1 08-02-2009 04:02 PM
add a second light to an existing 3 way switch circuit djohns10 Electrical 6 03-02-2007 07:16 PM
