Mid-circuit Problem - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-18-2011, 09:24 PM   #16
Rewards Points: 264
There is no GFCI in the bathroom, sorry, I should have noted that much earlier. Yes, no grounds, no GFCI, no joke.
I'll unwrap and rewrap everything and see if I can get this figured out. The fact that I get 120v in the ceiling box but the light wasn't working has me optimistic. I'd really like to know if that randomly ended wire in the attic is just a 3' run from the light and can be removed.
With no grounds going back the box what am would I be bonding it to? The box itself?
moneymgmt is offline   Reply With Quote
Old 01-18-2011, 09:50 PM   #17
Rewards Points: 506
Bonding the equipment to the junction box will do nothing unless the junction box is also bonded back to the panel. Your original post said this was an 'old part of the house'. Does this mean you have a gronding system in other parts of the house? Or even in the panel?
Others more knowledgeable than me will need to chime in, but I believe you can solve some absent grounding/bonding issues with GFCI devices strategically placed in the needed circuits. But, if the entire system is not grounded per current code then there may be more work involved.
This bonding discussion has nothing to do with your original problem.
jlmran is offline   Reply With Quote
Old 01-18-2011, 10:04 PM   #18
Rewards Points: 506
In the photo...what is the long black & white conductor with damaged insulation?????
Old 01-19-2011, 07:13 AM   #19
Rewards Points: 264
Yes, I refinished the kitchen and entire second floor, all with new wiring to a new panel.
I planned on adding a GFCI at R1 and in the bathroom.
That is the return hot from the light switch loop. I don't think it is burned, I believe that is residue from the incredible amount of 60yr old tape I removed but I will double check.
I woke up this morning with a new sense of "duh" so I turned the breaker back on, left the light switch wires disconnected and checked the rest of the circuit. Sure enough, everything works again. Honestly I didn't touch a thing other than disconnecting the stranded wires of the light fixture so I'm somewhat , but at the same time quite . I'm going to rewrap everything in there, add the two GFCI's, and hopefully we're good-to-go.
THANKS FOR EVERYONE'S HELP!!!!
Old 01-19-2011, 09:08 AM   #20
joed's Avatar
Rewards Points: 12,850
Use wire nuts. No tape needed.
Old 01-19-2011, 09:27 AM   #21
Rewards Points: 264
They make a nut for 4 12's?
Old 01-19-2011, 10:19 AM   #22
Rewards Points: 506
Yes...read the instructions on a package of wire nuts for guidance.
Old 01-19-2011, 11:23 AM   #23
I'm not sure what your local rules are but in a 2 wire system with no ground- we install a gfi at the first rec and wire to the load side on the outgoing wires, this protects everything after the plug. if it feeds a light first you could install a gfi near the panel.
You could replace all breakers with gfi (5ma)breakers (expensive).
I have used gfi's that are dead front, they look like a receptacle but they are blanked off, just buttons, no actual spot to plug into.
dhubz is offline   Reply With Quote
Dishwasher circuit tripping magnolia Electrical 5 10-29-2010 09:59 PM
Changing a 3 way circuit...using recessed lighting box as a junction box? Oxymoron Electrical 1 12-07-2009 06:46 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Circuit advice for finishing basement Straightgrain Electrical 16 03-25-2009 09:07 AM
Trane XE 80 Problem Espy HVAC 2 11-18-2008 05:31 PM
