Microwave Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 12-23-2012, 06:14 PM   #1
Microwave wiring
Doing a kitchen remodel where I have to move the microwave to another wall. The outlets are wired with #12 on a 20A breaker.
Here is my dilemma. Can I run a #14 from from the microwave to one the #12 outlets to run the microwave?
Fridge and stove are on a separate circuit so the only thing on this 20A is the kitchen receptacles and lights.
Thank you in advance and Merry Christmas!
sqzdog is offline   Reply With Quote
Old 12-23-2012, 06:28 PM   #2
Rewards Points: 528
If its not a permanent installed microwave(requiring dedicated circuit),and is counter top keep the 12 on it .
hidden1 is offline   Reply With Quote
Old 12-23-2012, 06:37 PM   #3
Rewards Points: 1,300
No. You can not use 14 gage wire on a 20 amp circuit.
danpik is offline   Reply With Quote
The Following User Says Thank You to danpik For This Useful Post:
Gac66610 (12-23-2012)
Old 12-23-2012, 06:45 PM   #4
The #14 would be branched off of one of the #12 outlets and will only power the permanently mounted microwave. Here are the specs for the microwave:
Product rated at 120v, 60 hertz, 15 amps and 1.70 kw. The power supply cord should be connected to a separate 15 to 20 ampre branch circuit single grounded outlet.
Old 12-23-2012, 06:48 PM   #5
Resi EC
Rewards Points: 252
You need a dedicated circuit for this appliance.
Do not run #14 on a 20a circuit
Gac66610 is offline   Reply With Quote
The Following User Says Thank You to Gac66610 For This Useful Post:
sqzdog (12-23-2012)
Old 12-23-2012, 07:43 PM   #6
Rewards Points: 528
Since permanent then you must have a dedicated 20 amp circuit 12G.NEC code section 210.52
The Following User Says Thank You to hidden1 For This Useful Post:
sqzdog (12-23-2012)
Old 12-23-2012, 10:03 PM   #7
Idiot Emeritus
Rewards Points: 1,492
Either a 15 or 20 amp circuit is code compliant. It needs to be a single receptacle, and the amp rating of the receptacle must match the amp rating of the breaker supplying it.
If it's a 15 amp breaker, #14 will be ok. If it's a 20, you'll need #12.
The only places that you can use #14 on a 20 amp circuit is a motor, welder, or HVAC unit.
Rob
Last edited by micromind; 12-23-2012 at 10:08 PM. Reason: Can't spell worth beans......
micromind is offline   Reply With Quote
The Following User Says Thank You to micromind For This Useful Post:
Old 12-24-2012, 12:24 AM   #8
Thank you Rob. Will rewire to a dedicated circuit over the holidays.
Old 12-24-2012, 06:37 PM   #9
Rewards Points: 528
If permanent microwave has the vent/fan light attatchment id surely go with the 20 amp/ 12G.(many manufactures recommend it anyway )
Old 12-24-2012, 07:43 PM   #10
Could I reduce the breaker to a 15A temporarily until I can run a #12 wire?
Old 12-24-2012, 08:00 PM   #11
joed's Avatar
Rewards Points: 13,712
That would be safe.
The Following User Says Thank You to joed For This Useful Post:
micromind (12-24-2012)
Old 12-26-2012, 12:21 PM   #12
Semi-Pro Electro-Geek
Rewards Points: 2,990
Originally Posted by jasson View Post
I think you cant run a #14 from the microwave to one the #12 outlets to run the microwave You should consult your user guide book to avoid experiments and loss.
It's kind of hacky, but there's no reason he can't. It's code compliant and safe as long as the breaker is 15A. It doesn't even violate the manufacturer's instructions, since they say the microwave "should" be connected to a dedicated circuit, not that it "must". It's just a recommendation.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
The Following 2 Users Say Thank You to mpoulton For This Useful Post:
sqzdog (12-26-2012), TTW (12-26-2012)
Old 12-26-2012, 12:46 PM   #13
TTW
TTW's Avatar
If there is #14 wire anywhere in the circuit, you must use a 15 amp breaker. Not recommended, but done. Also at the panel, the wire should be marked 15 amp only.
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
Old 12-26-2012, 12:47 PM   #14
Thanks. This will only be temporary. Maybe for 1 week. Just didn't want to burn the house down in the meantime if I fire up the microwave.
over-the-range microwave problem aumanpj Appliances 6 12-04-2010 05:46 PM
Microwave fan motor wiring (for diy project) majstersztyk Electrical 0 12-01-2010 09:56 AM
HELP. I really need some advice on how to remove an over the range microwave! justmeee Appliances 9 12-24-2009 03:47 AM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 02:40 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
