-   -   Microwave range outlet box (http://www.diychatroom.com/f18/microwave-range-outlet-box-112478/)
NDWG 07-30-2011 09:55 PM
I am trying to figure out how high to instal the outlet box for my microwave range before I put up the drywall in the kitchen.
a7ecorsair 07-30-2011 10:34 PM
In my last three houses, the microwave receptacle was in the cabinet above the microwave. Have you laid out your cabinet height for this area?
COLDIRON 07-31-2011 07:01 AM
Middle of the cabinet over the microwave, you will have to cut out the back of the cabinet to install the receptacle properly and drill a hole from the microwave up into the bottom of the cabinet. See microwave instructions.
oh'mike 07-31-2011 07:07 AM
Middle? Best on the right side as the exhaust vent runs through the middle.
Plus the cord is on the right.
Frequently the electrician will leave a whip for that---and use a remodeling box--or a surface mounted box----that's easier for the cabinet installation.
COLDIRON 07-31-2011 07:11 AM
Correction, Middle meaning vertical middle and yes to the right side. Also the final remark from my previous post. See Microwave Instructions.
electures 07-31-2011 10:04 AM
WHat type is it? If it mounts over the range, put the receptacle in the cabinet above the M/W. If it is a countertop unit with a trim kit, check where the vent is and keep it away from it. It does not have to be GFI protected either.
