Microwave Randomly Trips Breaker...or Does It? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-22-2013, 10:09 PM   #1
Microwave randomly trips breaker...or does it?
My built-in mircowave is on the same circuit as our kitchen lights. Every now and then, the microwave will cause a trip. Only the breaker doesn't switch off. It's still in the on position but an off/on flip gets things working again. It doesn't seem to matter if the lights are on or off and the microwave mode (defrost vs high power). That said, it does seem to happen more frequently in the colder months. I've replaced the breaker and it made no difference. Does anyone have an idea of what the cause and fix are?
ghome is offline   Reply With Quote
Old 02-22-2013, 10:17 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 152
Loose connection in the circuit somewhere, or a bad microwave.
A breaker never trips to the off position, but to a midway position.
They all have to be turned off and then back on to reset.
jbfan is online now   Reply With Quote
Old 02-22-2013, 10:33 PM   #3
Rewards Points: 12,914
Micro waves should be on there own circut.
The Following 3 Users Say Thank You to joecaption For This Useful Post:
COLDIRON (02-23-2013), frenchelectrican (02-24-2013), Speedy Petey (02-22-2013)
Old 02-22-2013, 10:38 PM   #4
dmxtothemax's Avatar
Rewards Points: 5,098
What is the power draw of the microwave ?
How many lights are on the same circuit ?
And how much power do they draw ?
Sounds like the circuit is running close to its limits,
And circuit breakers dont like running close
to there trip out point.
If the load exceeds 80% of the breakers rating
then you be needing a bigger circuit.
dmxtothemax is offline   Reply With Quote
Old 02-22-2013, 11:27 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
This is typical where folks replace a hood with an over-the-range micro/hood, and they ignore the instructions that say they require a dedicated circuit.
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
frenchelectrican (02-23-2013), gregzoll (02-22-2013)
Old 02-22-2013, 11:52 PM   #6
Rewards Points: 6,652
Speedy, or the fact that they just feel rules, schmools, they do not matter. Right now I am dealing with an issue with my brother on his place that he has enough electrical issues, in his 100+ year old house, that it can keep a crew of four busy for a couple of months in fixing it.
Old 02-23-2013, 02:33 PM   #7
Thank you everyone for the great ideas! The home was built in 95 and the microwave was made in 2006, so replacing a hood is a good guess. It is a 13 amp on a 15 amp breaker. I'm obviously interested in a safe/cheap/easy fix-in that order. What would you guys recommend? I assume I can't just replace the 15 amp with a 20 amp breaker, right? Anyone have an idea of what an electrician would charge for adding another circuit? Wondering if it'd be better to get a less powerful microwave, if there are any that operate at under 13 amps.
Thanks again!
Old 02-23-2013, 02:52 PM   #8
Thank you everyone for the great ideas! The home was built in 95 and the microwave was made in 2006, so replacing a hood is a good guess. It is a 13 amp on a 15 amp breaker. I'm obviously interested in a safe/cheap/easy fix-in that order. What would you guys recommend? I assume Anyone have an idea of what an electrician would charge for adding another circuit? Wondering if it'd be better to get a less powerful microwave, if there are any that operate at under 13 amps.
Thanks again!
"I can't just replace the 15 amp with a 20 amp breaker, right?"
Can't answer this until you say what size the wire is. #14 or #12?
Hardway is offline   Reply With Quote
Old 02-23-2013, 03:11 PM   #9
I don't know wire sizes well enough to eye it and the insulation has no visible label. However, I did compare the 15A vs 20A leads and the 20 were noticeably larger.
Old 02-23-2013, 03:51 PM   #10
Licensed electrician
Rewards Points: 1,054
The correct fix is to have a new circuit run just for the microwave.
If you were to upsize the breaker you would be creating a fire hazard.
Speedy Petey (02-23-2013)
Old 02-23-2013, 05:09 PM   #11
It's a pretty safe bet that it is #14. It's a lighting circuit in a typical house on a 15A breaker. No reason at all it would be #12.
Tags
breaker , microwave , trip
circuit breaker trips only when switch is wired in Upstater Electrical 12 10-17-2011 11:53 PM
Heat Pump trips breaker gt1935 HVAC 2 03-26-2011 11:06 PM
Microwave ground prong sparks/melts upon plugging it in microwaveman Electrical 30 05-10-2009 11:30 PM
20 Amp Breaker only trips once in a while panhandlion Electrical 14 11-26-2007 09:36 PM
breaker trips when too much is used lightone Electrical 11 04-29-2007 11:20 PM
