Microwave On Own Circuit? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-03-2011, 03:41 PM   #1
Microwave on own circuit?
I am finishing a basement for a relative. There is a 20 amp circuit around a mini bar area that will end up with 6-8 outlets on it. One of them will have a mini fridge all the time and another a microwave all the time. Not sure as to the wattage of the microwave or fridge because they have not been purchased yet. The microwave will not be used all that often. I read in an electrical book that microwaves are usually on their own circuit, but being a smaller secondary microwave is that necessary?
Also, the outlet next to sink will be GCFI, should all the others in the bar area be downstream and protected as well? Including the fridge and micro.
Thanks!
avmech is offline   Reply With Quote
Old 03-03-2011, 05:53 PM   #2
Scared Electrician
Saturday Cowboy's Avatar
truly this can only be answered by looking at the nameplates of the appliances.
However my bet is that you will find it better to have 2 circuits
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 03-04-2011, 05:05 AM   #3
Electrical Contractor
kbsparky's Avatar
A 20 Amp circuit should be adequate for the loads you have outlined, IMO.
But consider this: Should you also add something like a coffee pot, or a toaster/oven, that 20 Amp circuit may NOT be enough, when trying to nuke something at the same time while brewing your java, or toasting your sub roll.
-KB
Old 03-04-2011, 07:45 AM   #4
Just call me Andrew
Rewards Points: 1,020
If you feed the other outlets off the "Load" side of the gfci, they will also be protected.
Andrew
secutanudu is offline   Reply With Quote
Old 03-04-2011, 08:26 AM   #5
joed's Avatar
Rewards Points: 12,016
In Canada the fridge MUST be on a dedicated circuit.
Old 03-04-2011, 07:44 PM   #6
kbsparky's Avatar
Is that ALL fridges, or just the one in the main kitchen?
-KB
Old 03-05-2011, 07:43 AM   #7
Rewards Points: 3,130
Refrigerators do not require a GFI outlet, nor do microwaves. The only ones I would GFI protect are the countertop outlets. Your code may differ.
For some of the reasons already given, I would put the fridge on its own circuit. I'd also run two circuits for the countertop outlets, and alternate them so that no two on the same circuit are side by side. The microwave could be plugged into one of them.
You can never have too many outlets.
Old 03-05-2011, 02:22 PM   #8
Rewards Points: 530
When I wired my kitchen, I ran a circuit for the fridge and a circuit for the micro wave. I also ran a cfci for the counter top plugs.
Wife moved the micro wave and wants another circuit ran.
The dedicated circuit I ran for the micro wave is now used mostly just for a phone. But it is on the wall that goes out to the deck, so I might just tie into it and put a rec or two on the deck wall.
I have one outside rec, and it was one of the best things I ever did since I tend to piddle in the yard quite a bit sometimes.
Old 03-09-2011, 06:52 PM   #9
I think I'm going to go with 2 circuits. One for fridge and a few undedicated outlets, and the other circuit for the microwave. If your a qualified electrician and you would do otherwise let me know. remember that is is a bar area, so the fridge will be the only thing using power all that often.
Old 03-09-2011, 08:02 PM   #10
Electrician
SD515's Avatar
Rewards Points: 504
...Waiting to hear back from joe if this bar area needs a dedicated for it's fridge (Canadian rules)...just curious. Personally I would probably run 2 20A circuits, splitting them in half. 3 or 4 each. Set it up so the fridge & micro are on separate circuits. GFCI the recepts within 6 ft of the sink.
Kyle
Old 03-09-2011, 10:02 PM   #11
joed's Avatar
In Canada bar fridge does not require dedicated circuit. But I don't think we have confirmed where the OP is from.
From ESA Ontario website
Question
Does a receptacle for a bar mini-fridge require a separate circuit?
Answer
No, provided the receptacle is in a location that will accommodate a mini-fridge but not a full sized refrigerator. An example of such a space would be below a bar counter surface.
A mini fridge is defined as any refrigerator of less than 5.5 Cu ft capacity. The term mini fridge also includes the terms under counter fridge, bar fridge, wine cooler or chiller, beer or keg cooler, or other similar terms.
If the space will accommodate a full size refrigerator then a separate circuit is required.
Rule 26-720.
The Following 2 Users Say Thank You to joed For This Useful Post:
frenchelectrican (03-10-2011), SD515 (03-10-2011)
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Open circuit has power, close the circuit no power??? BeginnerHomeDIY Electrical 7 07-08-2009 03:40 PM
OTR Microwave installation bfarber Appliances 3 12-22-2008 08:55 PM
Microwave trips GFCI on a different circuit! Frank Kolwicz General DIY Discussions 7 06-01-2008 09:48 PM
