Microwave Dedicated Circuit? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-22-2008, 12:18 PM   #1
Rewards Points: 276
Microwave dedicated circuit?
Does code require a microwave to be on it's own circuit? I am interested to put it on its own circuit, but a couple of light bulbs after it wouldn't hurt right, unless code requires it to have it's own?
DIYGST is offline   Reply With Quote
Old 11-22-2008, 02:54 PM   #2
Is it built in?
If it isnt you can put it on a kitchen receptacle circuit, but cannot use any kitchen outlet circuits to power lights, only outlets.
rgsgww is offline   Reply With Quote
Old 12-03-2008, 02:08 PM   #3
Phil
It does not need to be on its own circuit but the built in microwaves come with a pigtail and the manufacturers specify that you have an outlet in an adjoining cabinet that it plugs into so in the event of a malfunction it can be easily unplugged.
Most microwaves draw no more than 1000 watts so you have an extra 800 watts on a standard 15amp circuit or an extra 1400 watts on a 20AMP circuit. Not enough to have a toaster over but certainly enough for a dozen lights.
Phillysun is offline   Reply With Quote
fridge on the same 20A circuit with microwave amakarevic Electrical 10 09-12-2008 09:45 PM
Dedicated circuit for washer/dryer TVC15 Electrical 4 07-27-2008 10:42 PM
Microwave trips GFCI on a different circuit! Frank Kolwicz General DIY Discussions 7 06-01-2008 08:48 PM
Dedicated freezer circuit in basement? budde97 Electrical 5 02-15-2007 03:09 PM
dedicated circuit for smoke detectors wiggs Electrical 11 04-24-2006 08:25 PM
