Methods For Running Ground Wire - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 10-23-2009, 07:59 PM   #31
Rewards Points: 246
Originally Posted by erikhaugen View Post
great! thanks. This is what I was assuming originally; thanks for reassuring me after the doubts raised here!
My question was is it ok to run the single green 12g wire in between the sole plate and the flooring, under the edge of the wall's sheetrock? So it will be lower than the top of the flooring, in that little 1/2 inch by 3/4 inch gap. If ok to do, this will be easy for me since we are replacing the baseboards anyway.
thanks!
If you can run a separate wire to ground the receptacles, why not do it right and pull new cables. Your exception may be valid.
What does the AHJ say about this project. I believe this is where you will find out if it allowed or not. We all know the AHJ has authority over the NEC.
If it worked before you worked on it. You did something wrong.
Old 10-23-2009, 08:08 PM   #32
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
I see no code violation in doing what your asking. You can fish that ground wire anywhere you want as long as it is free from physical damage. I don't think it's going to get damaged at the sill plate. Rodents sometimes chew wire but that is not easily prevented.
In accordance to 250. 130 (C) Where do you plan on terminating it?
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 10-23-2009, 09:30 PM   #33
Rewards Points: 1,548
(going around to the other side of the dead horse to continue beating it)
>>> ... all circuit conductors must be grouped together ...
My cursory look about the Internet tonight leads me to conclude that the ground wire (grounding conductor) is not a "circuit conductor"; we all know it does not normally carry current.
Back to the topic at hand, I would just merely go right ahead and run the ground wire in the channel between the lower edge of the drywall and the subfloor if that were convenient. This channel is very unlikely to be penetrated by nails.
Old 10-24-2009, 08:05 PM   #34
Thumbs up
It's kind of funny, I am having a _really_ hard time getting my question answered. I even asked on another similar forum. Even among people who know what they're talking about and believe it is permissible to run a lone ground between outlets, nobody will take a stand on whether it is ok to run it where I want to run it. I'm assuming such experts would have no problem with me notching the studs and using nail plates, but if that's what I have to do then it probably isn't worth it at this point. I guess I'll call the city; probably the best move anyway in cases where it isn't clear-cut to folks in forums like this.
thanks!
-erik
It (all) depends on your geographic location. Also, on what kind of lunch that particular inspector had. I'm not trying to be facetious. But there appear to be contradictory answers in the NEC. On the one hand, it appears that it is permissible to run a (supplemental; not really supplemental. Because that would create a potential parallel path to ground.) wire to the grounding rod. On the other hand, it appears that All the conductors must be in one cable. It must be well researched to see all the exceptions. (No matter what) Don't Drink and Drive, Ever!!!
spark plug is offline   Reply With Quote
Tags
ground receptacle
3 wire with ground to 3 prong dryer plug dgbunk Electrical 9 10-19-2010 01:07 PM
water meter ground wire jumper not needed? windowguy Electrical 13 07-21-2009 05:37 PM
Live ground wire in dryer Retired sailor Electrical 10 05-04-2009 03:26 PM
Installing light fixture.....ground wire? yummy mummy Electrical 15 02-19-2009 11:33 AM
connecting ground wire to ground screw amakarevic Electrical 10 12-24-2008 04:28 PM
