Meter In Wiring To Main Breaker Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 08-06-2012, 11:55 PM   #1
Meter in wiring to main breaker panel
I'm installing a flush mounted meter in box and a breaker panel side by side with a stud in between, Does the SER wire have to be in conduit if it is installed in the walls and the walls covered?
JGun is offline   Reply With Quote
Old 08-07-2012, 01:14 AM   #2
" Euro " electrician
frenchelectrican's Avatar
Oui et Non ( Yes and No ) depending on your state code requirment.
But I rather have this in the conduit for safety sake espcally with UNFUSED part I get few service call when someone was not aware that they did hit the service entrance cable and do pretty good damage when they short it out.
So that one reason why I rather run this in conduit for safety reason.
Oh btw SER cable can be a pain in butt when you try to snake them in the conduit so just go with THHN/THWN copper or XPLE/RTW alum conductors ( it must be dual rated otherwise it can not be used indoor at all )
Merci,
Marc
Old 08-07-2012, 10:56 AM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,116
Merci,
Marc
I agree.....
JGun....it helps to have your location in your profile.
But I'm willing to bet that it does. I pretty sure any new power line connections will require the use of a weatherhead....which can only attach to a metal pipe.....and you would have a hard time getting that pipe to stay up unless it goes all the way down to the meter.
Install the pipe....the last thing you want to happen is someone drive a screw through a wall into a 100A plus wire.....it wouldn't be pretty.
The Following User Says Thank You to ddawg16 For This Useful Post:
frenchelectrican (08-08-2012)
Outside breaker, inside main breaker panel, so is it a sub? CPF Electrical 29 02-01-2012 11:28 AM
new sub panel BlueBSH Electrical 11 01-22-2012 09:28 AM
Fuse panel main breaker question cjm94 Electrical 5 11-16-2011 10:16 AM
Melted Service Entrance Wire in Panel theatretch85 Electrical 13 08-22-2008 11:37 AM
main lug vs main breaker for sub panel diyll Electrical 1 01-17-2008 09:18 PM
