Old 07-13-2011, 01:25 PM   #1
meter vs. sum of circuit amperage
i was curious if the sum of all circuits' amperage has to be less or equal to what the meter brings in OR, as i would consider it to be realistic, each circuit can be assigned reasonable concurrent usage percentage, with which its amperage can be weighed to arrive to the sum.
e.g. if my subpanel has 50A, can i have 2 20s and a 15 circuit (total 55) considering that it is highly unlikely that at any given time every circuit would be maxed out?
thanks
Old 07-13-2011, 01:28 PM   #2
Mad Scientist
Yes. The total of the circuit breaker ratings is basically meaningless. I have a 100A service here with over 300A worth of breakers installed. The important thing is the actual calculated load. Consider that most of the time the load on a 20A receptacle circuit might only be 0-5A, with nothing, or just a few small things, plugged in.
McSteve is offline   Reply With Quote
The Following User Says Thank You to McSteve For This Useful Post:
amakarevic (07-13-2011)
Old 07-13-2011, 01:32 PM   #3
exactly what i thought. thanks for the clarification.
Old 07-13-2011, 03:11 PM   #4
joed's Avatar
The sum af all the circuits amperage(the actual amps being used) has to be less than the main.
The sum of all the breakers means nothing since many have no actual amps going through them at any one time. And none of them will have full load marked on the breaker going through them.
Do not PM with questions that can be asked in a forum. I will not respond.
The Following User Says Thank You to joed For This Useful Post:
Old 07-13-2011, 04:25 PM   #5
thanks but my question was referring to the breaker amperage.
Old 07-13-2011, 05:56 PM   #6
I=E/R
a7ecorsair's Avatar
The branch circuit breakers do not have to add up to be equal or less than the disconnect breaker. The breaker in the panel that feeds this panel has a breaker that is sized to the wire gauge that feeds this sub panel. The breaker in the sub is typically the same size but doesn't have to be.
a7ecorsair is offline   Reply With Quote
The Following User Says Thank You to a7ecorsair For This Useful Post:
What kind of meter can test amperage draw? jayp Electrical 6 05-02-2011 07:39 PM
New service Help (Meter can/ service mast Conduit help) cwolford Electrical 13 03-26-2011 08:55 PM
Possible Defective or Incorrect Electrical Meter? MorganB Electrical 10 01-18-2011 10:51 AM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 08:59 PM
Circuit out but circuit breaker didn't trip PaulenAndrew Electrical 17 08-16-2008 09:38 AM
