Meter Socket Connection - Electrical - DIY Chatroom Home Improvement Forum
Old 09-10-2012, 11:02 PM   #1
Rewards Points: 175
Hi Everyone,
As I've talked about in another post, I'm redoing my electric service/panel. I have a question about the connection from the panel to the socket.
I have 2" rigid connecting the panel to the meter socket. The piece of conduit is ~ 6' long. The conduit will enter the the meter socket through the back (no LB).
Will a hub like this:
http://menards.com/main/electrical/r...092-c-9538.htm
be an adequate connection between the conduit and the meter socket outside? Will this meet code?
If not could you offer suggestions?
Thanks!!
Flooring Installer. Ecological Restoration Technician. Green Building Enthusiast. Obsessed with insulating and air sealing.
wewantutopia is offline   Reply With Quote
Old 09-11-2012, 12:13 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,452
The hub is fine for rigid....but....I seem to recall entering a panel from the back is a No No.....but don't quote me on it....lets wait for sparky, kbuz, greg or some of the other experts to chime in
Old 09-11-2012, 05:56 AM   #3
Julius793's Avatar
There is no problem entering a panel from the back. To the OP why use rigid? Personally I would use PVC or emt.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 09-11-2012, 07:43 AM   #4
Rewards Points: 175
Thanks for the replies.
I'm using the rigid because when buying 10' pieces to get to the weatherhead I end up with the perfect size left over to get from the panel to the meter socket.
This hub and the conduit will go into the back of the meter socket, it will come out of the top of the breaker panel into a rigid LR (which I've bought already) into the back of the meter socket.
So this hub is acceptable for an outside waterproof connection to the back of the meter socket? Do I need something else too? A bonding bushing or something?
Thanks!
Old 09-11-2012, 08:36 AM   #5
this is called a meyers hub and is used for outside work
Mule98 is offline   Reply With Quote
Old 09-11-2012, 11:24 AM   #6
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I can't see a problem with it, but you will still need a 2" rigid connector and ground bushing on either the socket or the panel for the cut end of the conduit.
Old 09-11-2012, 08:59 PM   #7
Rewards Points: 175
Great, thanks for the replies.
By rigid connector I assume you mean one of these?
http://menards.com/main/electrical/r...115-c-9538.htm
I was going to have the cut end of the rigid threaded. Do I still need the the compression connector?
As for the ground bushing, I will have one on the panel side. Do I need on also on the socket side?
This is what I got:
http://menards.com/main/electrical/r...865-c-9538.htm
Am I right to assume that there will be a ground wire from that lug to the ground bus bar?
Thanks again guys!
Old 09-12-2012, 06:19 AM   #8
Julius793's Avatar
Thanks again guys!
That is correct however if you are making yur own knockouts I don't think you need the ground bushing.
Old 09-12-2012, 06:58 AM   #9
Licensed electrician
Rewards Points: 1,478
Does your power company allow connections out of the back of the socket?
Old 09-12-2012, 07:36 AM   #10
Rewards Points: 175
I am not making my own knockouts, there are pre-made knockouts on the back of the meter base.
My POCO is ComEd. That is a good question if they accept back connections or not. Their literature as to their requirements don't mention it specifically... some of the illustrations do show conduit exiting through the base.
I guess I'll have to call them later.
Section 310.15(B)(6) vs. 210.4. Don't assume, call your friendly AHJs! Daneel Electrical 3 04-11-2012 07:24 AM
Is My Electric Meter Correct: Conclusion. fcfcfc Electrical 0 10-03-2010 06:00 PM
How does electricity meter calculate kwh? deerhunter Off Topic 18 09-06-2010 08:26 AM
residential water meter connection nix Plumbing 0 05-16-2010 07:28 PM
Water Meter connection Ultrarunner2017 Plumbing 4 03-17-2009 10:11 PM
