Old 09-23-2012, 05:05 PM   #1
meter socket
i have a 200A meter socket that is made for overhead service, can i pun a blank on the top hole and use the K/Os on the bottom for my conduit
Mule98 is offline   Reply With Quote
Old 09-23-2012, 05:14 PM   #2
Code05's Avatar
meter socket
In many cases yes; however, it has to be the correct blank cover for the meter base.
Code05 is offline   Reply With Quote
Old 09-23-2012, 05:20 PM   #3
Electrical Contractor
meter socket
Yes, but you have to use one made for that meter base.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 09-23-2012, 07:25 PM   #4
meter socket
No! Underground meter bases have to have a barrier seperating line from load.
bobelectric is offline   Reply With Quote
Old 09-23-2012, 07:48 PM   #5
Code05's Avatar
meter socket
Many meter bases are designed for over head and underground/lateral service.
What barrier? Never seen a resi meter base with any type of barrier.
Got a link to this design?
Old 09-23-2012, 08:27 PM   #6
meter socket
I've only seen the barrier on all in one meter bases.
The Following 2 Users Say Thank You to jbfan For This Useful Post:
Code05 (09-24-2012), frenchelectrican (09-23-2012)
Old 09-23-2012, 11:36 PM   #7
" Euro " electrician
frenchelectrican's Avatar
meter socket
It can be done mais see my comment below.
Only few underground specfic meter socket and all in one box which I know they do have them but for oveheader's none what I know of.
Mule98.,
Let me give you a head up if you going to converted from overhead to underground I am seriouslly that you check with POCO to see if they can keep that socket otherwise you will have to get a underground meter socket that part you will need to check into before you get too far with it.
If your POCO do keep that one and converted to underground conduit go the largest you can most case it will be either 2 or 2.5 inch size and may end up useing expaning sleeve to prevent any damage in case you have hard frost in your area.
Merci,
Marc
Old 09-24-2012, 12:38 AM   #8
Code05's Avatar
meter socket
Good point, I was not thinking of meter combos, only straight bases.
Meter Socket Connection wewantutopia Electrical 9 09-12-2012 08:36 AM
400 Amp Meter Socket Upgrade, Can I Re-use Existing Metered Panel? macp123 Electrical 6 04-06-2012 03:04 PM
Meter socket distance from wall 7SistersRanchTX Electrical 2 02-28-2012 11:40 AM
Can the meter socket itself be replaced? Johnd85053 Electrical 19 02-14-2012 07:02 AM
Need to move meter socket Rustygaff Electrical 3 11-28-2010 10:44 AM
