Meter And Open Meter Pan Pictures - 200amp? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-11-2013, 02:41 PM   #1
Meter and open meter pan pictures - 200amp?
Hi. I finally got around to opening up my meter pan that is servicing the existing 100amp panel that I am upgrading to a 200 amp panel.
It seems to me that the meter and pan are rated for 200amps (see pics). Am I correct?
If the pan is already rated for 200amps and I don't need to switch it then do most people (electricians) simply pull the meter and run new/heavier wire from the pan to the new service panel while the power is on or should I pay the $214 and have the electric company do a disconnect at the pole since this is an underground feed?
Thanks!!!
Meter and open meter pan pictures - 200amp?-2013-04-08-14.17.53.jpg   Meter and open meter pan pictures - 200amp?-2013-04-08-14.19.42.jpg   Meter and open meter pan pictures - 200amp?-2013-04-08-14.20.21.jpg
CapeCod153 is offline   Reply With Quote
Old 04-11-2013, 02:47 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 494
Yep, that is a 200 amp rated meter.
depending on how the meter to panel is wired, if should be fairly easy to replace the feed to the panel.
jbfan is online now   Reply With Quote
Old 04-11-2013, 03:02 PM   #3
OK - thanks. Do I need a special tool to pull a meter or do they vary in how they are "plugged in"?
Old 04-11-2013, 03:07 PM   #4
jbfan's Avatar
Rewards Points: 494
Depending on your local, pulling the meter could be an unlawful act.
The meter just unplugs, and I don't really recommend it.
The Following 3 Users Say Thank You to jbfan For This Useful Post:
frenchelectrican (04-11-2013), Jim Port (04-11-2013), Speedy Petey (04-11-2013)
Old 04-11-2013, 03:13 PM   #5
eastcoastsparky's Avatar
Rewards Points: 150
You shouldnt really do it unless you have been trained and done it before, but if you do, you have to pull or i usually do, pull the line side out first to prevent any arcing and make sure the main breaker is off
eastcoastsparky is offline   Reply With Quote
Old 04-11-2013, 03:14 PM   #6
Do you recommend not unplugging it for safety or legally?
I am the homeowner doing my own electrical work (with a permit). When I spoke to the electric company they said I need to sign a waiver stating such but they only need to get involved if I need to disconnect the power or switch the meter. But I can confirm that with them again when I obtain the waiver. they also said I will need to submit proof of inspection, but that is usually with the disconnect.
Old 04-11-2013, 03:17 PM   #7
Once I pull the meter, doesn't that cut the power from the meter to the service panel?
It might be best if I simply pay to have the electric company disconnect the power. I was going to pay an electrician to do this anyway.
Old 04-11-2013, 03:18 PM   #8
Rewards Points: 150
Yes it cuts power to your panel but the incoming feeds are still hot, and since youll be working around in there i recommend just paying for the disconnect for safety reasons
Old 04-11-2013, 03:20 PM   #9
Rewards Points: 43
Smile
Novatek Electirc inc.
Contact a professional!
Last edited by beenthere; 04-11-2013 at 03:32 PM. Reason: Removed company name and links.
bugmenot is offline   Reply With Quote
Old 04-11-2013, 03:23 PM   #10
Yeah, that would ruin my day if I bumped the wrong thing! thanks
Old 04-11-2013, 03:25 PM   #11
Rewards Points: 150
Ha!! It will definetly do more than ruin your day
Old 04-11-2013, 03:34 PM   #12
Not sure what area you are from (guess Montreal) but due to superstorm Sandy I can't find any electricians in my area willing to take on such a small job right now. So I will pay to have it disconnected and I think I should be able to figure out the rest - good thing I have a generator as it will probably just take me 10x as long!
Old 04-11-2013, 03:38 PM   #13
Rewards Points: 150
Im in pennsauken, nj. I would like to help you but ive been busy lately. Private message me if you have any questions
The Following User Says Thank You to eastcoastsparky For This Useful Post:
CapeCod153 (04-11-2013)
Old 04-11-2013, 03:42 PM   #14
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Also plan on not getting power back till you have passed inspection and the inspector has called it in.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 04-11-2013, 03:52 PM   #15
Thanks, I appreciate that.
Water Meter and Irrigation Control segal Plumbing 1 10-07-2012 06:45 AM
What size wire for 150ft run from meter fitchetm Electrical 14 09-22-2012 06:20 AM
Rigid to meter connection and bonding? iminaquagmire Electrical 2 11-11-2011 10:18 AM
320Amp double lug meter - (2) 200amp panels 1texasguy Electrical 31 07-15-2011 10:47 AM
New clamp meter question Chevyman30571 Electrical 18 02-21-2010 11:35 PM
