-   -   Meter and open meter pan pictures - 200amp? (http://www.diychatroom.com/f18/meter-open-meter-pan-pictures-200amp-176863/)
CapeCod153 04-11-2013 02:41 PM
3 Attachment(s)
Hi. I finally got around to opening up my meter pan that is servicing the existing 100amp panel that I am upgrading to a 200 amp panel.
It seems to me that the meter and pan are rated for 200amps (see pics). Am I correct?
If the pan is already rated for 200amps and I don't need to switch it then do most people (electricians) simply pull the meter and run new/heavier wire from the pan to the new service panel while the power is on or should I pay the $214 and have the electric company do a disconnect at the pole since this is an underground feed?
Thanks!!!
jbfan 04-11-2013 02:47 PM
Yep, that is a 200 amp rated meter.
depending on how the meter to panel is wired, if should be fairly easy to replace the feed to the panel.
CapeCod153 04-11-2013 03:02 PM
OK - thanks. Do I need a special tool to pull a meter or do they vary in how they are "plugged in"?
jbfan 04-11-2013 03:07 PM
Depending on your local, pulling the meter could be an unlawful act.
The meter just unplugs, and I don't really recommend it.
eastcoastsparky 04-11-2013 03:13 PM
You shouldnt really do it unless you have been trained and done it before, but if you do, you have to pull or i usually do, pull the line side out first to prevent any arcing and make sure the main breaker is off
CapeCod153 04-11-2013 03:14 PM
Do you recommend not unplugging it for safety or legally?
I am the homeowner doing my own electrical work (with a permit). When I spoke to the electric company they said I need to sign a waiver stating such but they only need to get involved if I need to disconnect the power or switch the meter. But I can confirm that with them again when I obtain the waiver. they also said I will need to submit proof of inspection, but that is usually with the disconnect.
CapeCod153 04-11-2013 03:17 PM
Once I pull the meter, doesn't that cut the power from the meter to the service panel?
It might be best if I simply pay to have the electric company disconnect the power. I was going to pay an electrician to do this anyway.
eastcoastsparky 04-11-2013 03:18 PM
Yes it cuts power to your panel but the incoming feeds are still hot, and since youll be working around in there i recommend just paying for the disconnect for safety reasons
bugmenot 04-11-2013 03:20 PM
Novatek Electirc inc.
Contact a professional!
CapeCod153 04-11-2013 03:23 PM
Yeah, that would ruin my day if I bumped the wrong thing! thanks
eastcoastsparky 04-11-2013 03:25 PM
Ha!! It will definetly do more than ruin your day
CapeCod153 04-11-2013 03:34 PM
Not sure what area you are from (guess Montreal) but due to superstorm Sandy I can't find any electricians in my area willing to take on such a small job right now. So I will pay to have it disconnected and I think I should be able to figure out the rest - good thing I have a generator as it will probably just take me 10x as long!
eastcoastsparky 04-11-2013 03:38 PM
Im in pennsauken, nj. I would like to help you but ive been busy lately. Private message me if you have any questions
rrolleston 04-11-2013 03:42 PM
Also plan on not getting power back till you have passed inspection and the inspector has called it in.
CapeCod153 04-11-2013 03:52 PM
Thanks, I appreciate that.
