Meter & Main Service Panel Upgrade From 100amp To 200amp - Electrical - DIY Chatroom Home Improvement Forum
Old 03-25-2013, 09:51 AM   #1
meter & main service panel upgrade from 100amp to 200amp
Hi. I need to upgrade my service to 200amp and early on I thought I would do all of the electrical work myself, so I bought the materials. Now I would like to hire a referred electric contractors to do the meter swap/service hookup but I'm having a difficult time getting anyone to stop out since this is such a small job, I already have the materials and everyone is busy due to Superstorm Sandy.
The existing meter is supplied via underground wiring (this was done about 15 yrs ago when the house was moved to its current location). I called the electric company and I was told that since this is an underground feed there will need to be a connect/disconnect done by them if the meter pan needs to be swapped out. If the meter pan doesn't need to be swapped out then the meter can simply be pulled & switched. They told me an electrician will determine if the meter pan is acceptable.
This job is my own residence and we gutted the house and added an addition. My experience with electric is wiring this entire house, including pre-wiring the new circuits for the 200amp main service panel. I've never worked on a meter or hooked up a service panel to a meter.
Any comments or advice if I was to try this myself? Is there a way I can tell if the existing meter pan will work with a 200amp meter?
Thanks!
CapeCod153 is offline   Reply With Quote
Old 03-26-2013, 08:12 AM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Is this a repost?
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 03-26-2013, 08:23 AM   #3
Delete this post
sort of. Nobody responded to this question of my 2 questions in my other post so I said in the other post I would post this question again. But then all of you guys started answering me in my other post. I didn't see a way to delete this post so I was hoping it would shrivel on the vine.
Moderators - you can delete this post. Thank you.
The Following User Says Thank You to CapeCod153 For This Useful Post:
electures (03-26-2013)
Section 310.15(B)(6) vs. 210.4. Don't assume, call your friendly AHJs! Daneel Electrical 3 04-11-2012 08:24 AM
400 Amp Meter Socket Upgrade, Can I Re-use Existing Metered Panel? macp123 Electrical 6 04-06-2012 03:04 PM
changing to 200 amp service mbaldwin Electrical 3 03-29-2012 09:00 AM
Grounding for two service entrances to same house. jogr Electrical 18 09-24-2008 11:31 AM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 11:27 AM
