Meter/main Questions - Electrical - DIY Chatroom Home Improvement Forum
Old 07-27-2012, 05:06 PM   #1
meter/main questions
Hi all, a few questions for the experts. Can I run a 200 amp sub panel in my house , which is now a 100 amp main due to the old service entrance is rated at 100 amp , I changed out the 200 amp main to a 100 amp 10 years ago when I put the panel in. Want to install a 200 Amp meter/main and run the house main as a a sub panel off the feed thru lugs , and put the 100 amp breaker I switch out of it into the meter/main to feed the 4-wire underground to the 100 amp main breaker sub in the garage. Seems easier than ripping the panel off the wall to run the entrance and sub thru the back of it as it is all finished and boring thru 10" poured concrete will not be fun. I understand they changed the nec on feeders . was going to use 2/0 from the poco line to the meter/main and to the house panel and 3-2 wires with a 4 ground to the garage panel. have installed 2-ground rods 80" apart with bare 6 wire at both the house and at the garage. Any thoughts? Speedy...Jim Port...any takers?
Amazingglazier is offline   Reply With Quote
Old 07-27-2012, 05:26 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Where is the meter located? Attached to the structure?
Old 07-27-2012, 05:45 PM   #3
Yes on the driveway side .
Old 07-27-2012, 05:47 PM   #4
Just don't get the idea of poking 2 new holes thru the wall to run the new se wires in and go back out to the garage.
Old 07-27-2012, 05:48 PM   #5
E2 Electrician
So is the existing panel inside rated for 200 amps? If so, I say your plan is good, you wont need another disconnect inside... if the garage is detached, you will need a disconnect at the garage, if it is attached, you only need to protect the feeder at the meter/main.
Old 07-27-2012, 05:50 PM   #6
E2 Electrician
They wont be service entrance wires if the meter contains a main breaker, they will be feeders at that point. So you will need 4 conductors from the meter main to the existing panel, and you will have to separate the grounds and neutrals inside that panel.
Old 07-27-2012, 06:08 PM   #7
Master Electrician
I second this. Doubt your existing panel is rated for 200a. You can't just swap out mains. The equipment has to be rated for it.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 07-27-2012, 06:11 PM   #8
E2 Electrician
Right, but.... You can just install a 100 amp breaker in the meter main for the existing panel. If that helps.
Old 07-27-2012, 06:18 PM   #9
The existing panel is definately rated for 200 amps it is a ge tm I put in 10 years ago when I separated each room to it's own breaker, at that time I removed the 200 amp main and put a 100amp 22kaic breaker in it's place, so yes I will just swap the 200 back in, on this panel they bolt in as a normal breaker using 2 screw down tangs on each leg, I put the 100 on the 2 center tangs resulting in the ability to use the extra breaker slot capacity but not overloading the current 100 amp service.
Help How to Wire Bathroom "Fan Heater Light Night-light" unit, and questions Tryvidy Electrical 9 06-18-2012 02:37 PM
Newbie questions on refinishing walkup attic with knee walls FileOpen Insulation 2 11-19-2011 11:31 PM
Basic (hopefully) electrical questions k2000lbs Electrical 10 04-27-2011 12:59 PM
How thick should my thinset be? yummy mummy Tiling, ceramics, marble 20 09-28-2009 12:36 PM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 10:56 PM
