Meter Main Problem. Right-sided Meter? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-23-2011, 05:25 AM   #1
Meter Main problem. right-sided meter?
My panel is installed inside the garage against a wall perpendicular to a small window. The meter is read through this small viewing window. My old smaller panel was mounted at an angle so that the meter can be read. My new panel is much bigger due to added new circuits and cannot be mounted this way. My electrician has opted for a meter main combo mounted flat against the perpendicular wall. Problem is that the meter cannot be read now.
So a couple questions:
1. I've seen adapters for the meter that turns it 90 degrees from the meter base. Does anyone know what that's called and where to get one?
2. Turning the meter 90 degrees where it is won't work since it will block the circuit breakers on the right. Is there a meter main combo panel where the meter is on the right side, and the circuit breakers on the left?
Last resort is to split up the meter base and main panel. I would still need to angle the meter to be viewable though.
acerunner is offline   Reply With Quote
Old 07-23-2011, 08:26 AM   #2
Rewards Points: 1,538
In addition the meter is farther away from the window than before (as you have shown it) and harder to read even if the meter faced the window.
Can you read the meter yourself and send in the readings each month?
Can the power company install a meter with remote control reading capability? (Probably fits in the same meter socket)
While you could mount a mirror so the meter can be seen from the outside, the view will be backwards and the chances of read errors are increased.
AllanJ is online now   Reply With Quote
Old 07-23-2011, 09:35 AM   #3
Electrical Contractor
kbsparky's Avatar
The poco usually provides and installs the 90 degree adapter. I've seen them installed on roadside poles for utility transponders and boosters, so they can read the meter without getting out of the truck and walking through a ditch.
-KB
Old 07-23-2011, 10:02 AM   #4
crankcase's Avatar
deleted post
crankcase is offline   Reply With Quote
Old 07-23-2011, 10:12 AM   #5
joed's Avatar
Rewards Points: 13,332
The POCO here would have forced the new meter to be outside. Also we have smart meters so no one has to actually come and look at it.
Old 07-23-2011, 12:40 PM   #6
Sparky
Rewards Points: 510
same here.... they wouldnt let you upgrade an interior meter, would have to go outside
Techy is offline   Reply With Quote
Old 07-23-2011, 12:41 PM   #7
the picture is not to scale. The meter IS a little further but not too much.
I've had to phone in the readings the last couple months, but this is a temporary solution at best. Not sure if POCO allows doing this regularly. It is also very inconvenient.
Around here, it is very common for the meter to be inside like it is with mine. Smart meters are available, but I am reluctant to make the switch due to many complaints I've heard about its accuracy and overcharging. For now, I opt to avoid them.
So back to my original question. Is there no such thing as a meter mounted on the right side of a meter-main combo?
Main water shutoff problem GoodoleBob Plumbing 18 06-16-2011 10:33 PM
Height of meter box Arky217 Electrical 4 05-23-2011 10:56 AM
Leaky water main before meter ChrisSask Plumbing 4 03-25-2011 07:53 AM
Converting Main Panel to Sub: How to jumper? HomeOwner42 Electrical 46 02-19-2009 03:28 PM
Problem with Main Line or Not? reibuild Plumbing 2 05-02-2007 10:41 AM
