Meter And Main Install - Electrical - DIY Chatroom Home Improvement Forum
Old 01-10-2011, 07:02 PM   #1
meter and main install
Could i install my meter box, main, breaker panel and the ppl inspector would then inspect
and then they would power it without any breakers being installed at the time. I live in pa.
florpro is offline   Reply With Quote
Old 01-10-2011, 09:34 PM   #2
Electrical Supplier
Rewards Points: 150
they do it here in ohio. As long as all connections are made, covers installed etc, they energize services.....I dont see why not.
Usually breakers are only required for final inspections. Not roughs or service installs.
"Do it right the first time and avoid duplication of effort"
Your AHJ/Inspectors ALWAYS have the final say on ANY electrical code issue.
If in doubt, contact a licensed, experienced, reputable electrician to perform the work.
LyonsElecSupply is offline   Reply With Quote
Old 01-11-2011, 01:28 AM   #3
" Euro " electrician
frenchelectrican's Avatar
Only if your area allow homeowner to install the service entrance set up and it have to be permited and have it inspected by electrical inspector before the POCO can able engerized the system.
So check with the inspection department before you do anything first.
There are some local area may not allow homeowner to do it and I know for sure Apartment complexes , some multifamily units and commercal locations are off limit to owners they have to get a hold of electrician to deal with it.
Before going anyfurther what size load centre are you plan to install in ?
Merci.
Marc
Old 01-11-2011, 04:27 PM   #4
Merci.
Marc
I plan to go 200 amps
Old 01-11-2011, 04:55 PM   #5
Sfeyelectric's Avatar
What part of Pa?
Sfeyelectric is offline   Reply With Quote
Old 01-11-2011, 05:01 PM   #6
Originally Posted by Sfeyelectric
What part of Pa?
Lancaster, county
Old 01-11-2011, 05:04 PM   #7
Lancaster, county
Ok not sure with that area, best thing is to call your local code enforcement office and see. Most of Pa outside of the bigger cities you are permitted to work on a home you own and occupy!
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
Main 50 amp breaker in meter room keeps tripping Dennis Diaz Electrical 7 04-21-2010 08:42 AM
2 main breakers, one meter jacky12b Electrical 3 04-18-2009 09:37 AM
Running new Main supply from Meter PEX or PVC? twilightcall Plumbing 7 08-03-2008 08:00 AM
Turning main power supply off from the meter amakarevic Electrical 2 05-22-2007 11:33 PM
