Meter Grounding - Electrical - DIY Chatroom Home Improvement Forum
Old 03-08-2013, 04:38 PM   #1
Question
meter grounding
Hello,
I am new here and since we're doing a major construction, i am positive this will not be the last. anyway I was wondering if anyone can give me a quick opinion about the way the electrician grounded our new service panel in our semi-new construction. I asked our general contractor that this looks terrible and he said that's the way it suppose to be and is within code and there's nothing else they can do, is that correct?
is that the way it's suppose to be?
Thanks for any comment
http://www.diychatroom.com/members/s...6273-photo.jpg
sdieddie is offline   Reply With Quote
Old 03-08-2013, 04:56 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 554
Yea, that does look terrible.
Can you take a close up?
Old 03-08-2013, 05:20 PM   #3
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Should have been able to do better than that.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 03-08-2013, 05:44 PM   #4
so what can be done about that? i don't want to offend him, should i ask to have them re-do this? he said this all they can do so maybe they will not.
Could this be re-done at the later date?
Thanks,
Old 03-08-2013, 07:07 PM   #5
rrolleston's Avatar
Those are water pipe grounding clamps not ground rod clamps.
Old 03-08-2013, 08:23 PM   #6
rrolleston's Avatar
I prefer the ground rods really close to the building and in a case like this I come out of the building with conduit and an lb to protect the ground and bury the ground rod and clamp below the ground surface. And I always use two rods because it's required here.
Old 03-08-2013, 09:19 PM   #7
Licensed electrician
Rewards Points: 1,788
I don't know why they used flex over the GEC. It is not a listed means of protection. The GEC could have followed the building surface.
The top of the rod needs to be flush or below grade.
stickboy1375 (03-09-2013)
Old 03-09-2013, 01:46 AM   #8
Rewards Points: 512
A licensed electrician did not do this; it's a god awful sight, and you should look into spending the money on a reputable, licensed, insured, and bonded electrician. Chalk up the extra cost to experience.
I'd love to see pics of what he done in other areas of the project.
EDIT: A 1st year apprentice would have done better
The Following User Says Thank You to sirsparksalot For This Useful Post:
TTW (03-09-2013)
Old 03-09-2013, 03:05 AM   #9
Thanks,
gregzoll this is how we do it in Northern Michigan!
Hardway is offline   Reply With Quote
Old 03-09-2013, 06:36 AM   #10
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
I am also VERY curious to see the other end.
The Following User Says Thank You to Speedy Petey For This Useful Post:
NJMarine (03-09-2013)
Old 03-09-2013, 10:11 AM   #11
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
I wouldn't be surprised if he cut 6' off the rod ... Also judging from the length of the bolts on the clamps I'd say those are water pipe clamps not ground rod clamps.
Just so the OP gets the general idea
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
The Following User Says Thank You to Stubbie For This Useful Post:
sdieddie (03-09-2013)
Old 03-09-2013, 06:02 PM   #12
Angry
Thanks for all your replys! I will insist he bury it underground.
in fact he does have a license (so cali)
so what does a rod grounding clamp look like?
so i can show him that i am not nieve and do not know
what i am talking about
thanks again
Old 03-09-2013, 06:12 PM   #13
Rewards Points: 83
like dis
mech_gui is offline   Reply With Quote
The Following User Says Thank You to mech_gui For This Useful Post:
Old 03-12-2013, 02:44 PM   #14
Its hard for me to see if the metal conduit is used as the ground or if there is a copper wire inside it that is used for the ground. Preferable everything would be copper or brass to prevent galvanic corrosion. It looks like at the very least the conduit and the screws are not copper or brass.
The clamp and the screw should both be copper or brass.
This link has some tips on what to look for also.
http://www.nachi.org/grounding-electrodes.htm
chris_b is offline   Reply With Quote
Water Meter and Irrigation Control segal Plumbing 1 10-07-2012 06:45 AM
What size wire for 150ft run from meter fitchetm Electrical 14 09-22-2012 06:20 AM
Grounding Switches.... stickboy1375 Electrical 3 08-03-2012 06:59 AM
New service Help (Meter can/ service mast Conduit help) cwolford Electrical 13 03-26-2011 07:55 PM
Grounding Confusion regularguy Electrical 8 03-06-2010 10:27 AM
