Meter Base And Disconnect Grounding - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-26-2013, 10:31 AM   #16
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Originally Posted by sirsparksalot View Post
Article please? It's done all the time around here, as I hear
NEC 312.6 and Tables.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
The Following User Says Thank You to electures For This Useful Post:
stickboy1375 (03-26-2013)
Old 03-26-2013, 10:57 AM   #17
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
When doing mobile home installs here I buy two 10' 6x6 and bury them 4' in the ground then run a couple 2x8 treated between them and mount a meter main to it. In the POCO rule book here a meter pedestal has to be on two 6x6 posts set 4' in the ground. How will you wire between the two when they are back to back on a 6x6?
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
The Following User Says Thank You to rrolleston For This Useful Post:
sirsparksalot (03-26-2013)
Old 03-26-2013, 01:39 PM   #18
Rewards Points: 512
Originally Posted by stickboy1375 View Post
So how high off the ground is the main breaker?
That would be about 4.5'-5', I guess. The post is 4' off grade.
Old 03-26-2013, 01:45 PM   #19
Rewards Points: 512
I never said it was easy, but it's done. Aside from the bending-radius requirements of the wires, I think it's a fair install.
Old 03-26-2013, 01:49 PM   #20
Rewards Points: 512
Yeah, I'll remember this in the future. Unfortunately, our POCO doesn't even give us a print of what they require. On the flip side, Northern Indiana's POCO does.
Old 03-26-2013, 04:09 PM   #21
rrolleston's Avatar
This is and example of what our install's look like.
Old 03-26-2013, 06:38 PM   #22
Rewards Points: 512
Attachment 68067
More digging!
I'm sure mine would have been fine had I gotten a 6x6x10' (instead of the 8'), and I would have taken more time in looking at what I had, measurement-wise)
Mine should have been centered, and not coming atop the post.
Main panel Bonding and grounding tulk Electrical 12 11-28-2012 11:19 PM
Section 310.15(B)(6) vs. 210.4. Don't assume, call your friendly AHJs! Daneel Electrical 3 04-11-2012 08:24 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
320 amp meter JONBOY Electrical 17 02-04-2010 07:14 PM
Question on Code w/regards to holes in Meter Bases or Panels etc. tsenator Electrical 10 10-22-2009 11:37 AM
