Metallic To Electronic Ballast Conversion Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 12-22-2013, 03:05 PM   #1
Metallic to Electronic Ballast Conversion Wiring
My current light fixtures have two metallic ballasts. There are two separate wires coming into the fixture with each wire supplying a hot and neutral to each ballast. The grounds were connected together with the ground on the fixture. I want to replace these ballasts with one electronic 4 lamp ballast. There is only one white and one black wire on the ballast.
What do I do with the two house wires? Connect all 3 blacks and all 3 whites or cap off one of each and just use one house wire. Are there two house wires because all of the strip lighting fixtures are connected together?
Hopefully I have supplied enough information. I have diagrams if needed.
Brewer12 is offline   Reply With Quote
Old 12-22-2013, 04:26 PM   #2
joed's Avatar
Rewards Points: 12,854
Are these current MAGNETIC ballast controlled by one switch or two switches? If one switch I would just cap the extra set with two wire nuts and use one set for your new ballast.
Old 12-22-2013, 05:19 PM   #3
All of the fixtures are controlled by one breaker switch and multiple wall switches.
Old 12-22-2013, 05:22 PM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Is this a commercial property?
Old 12-22-2013, 05:50 PM   #5
No, residential.
Old 12-22-2013, 05:53 PM   #6
k_buz's Avatar
If you want the fixture to be switched as it was, you will need to use two two lamp ballasts.
Old 12-22-2013, 07:13 PM   #7
Ok. So using a 4 lamp ballast, it might on all the time without operation from a switch?
Old 12-22-2013, 09:29 PM   #8
joed's Avatar
Did one or two switches control this fixture?
If two switches then you need two ballasts if you want it the same.
Old 12-22-2013, 11:33 PM   #9
There are 6 fixtures with 2 ballasts each. They are all 4-lamp fixtures so 12 ballasts total. There are 8 ballasts in one room operated by 3 switches and 4 ballasts in another room operated with 1 switch. All ballasts are on the same breaker switch.
Old 12-23-2013, 05:49 AM   #10
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
Hopefully you are also converting from T12 to T8 lamps
Coastal South Carolina
Old 12-23-2013, 07:07 AM   #11
Yes, I am going from T12 to T8.
Old 12-23-2013, 07:34 AM   #12
joed's Avatar
You still have not answered if the two ballasts are operated by separate switches. That would seem logical since there would be no other reason to have two feeds into a fixture.
Old 12-23-2013, 08:07 AM   #13
Joed here is my answer about the switches.
Old 12-23-2013, 01:09 PM   #14
joed's Avatar
8 ballasts operated by 3 fixtures does not tell if both ballasts in one light are operated by one switch.
Old 12-23-2013, 04:25 PM   #15
Joed,
My apologies.
There are 4 fixtures from left to right. The left switch operates both ballasts in the left fixture. The middle switch operates one ballast on each of the other three fixtures and the same for the right switch.
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 10:33 AM
Help!!!!!! Hps Ballast Wiring whitekid135 Electrical 1 03-30-2008 11:05 AM
Wiring plug to Mercury High Intensity ballast Dustin Electrical 2 05-29-2007 04:56 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
