Metal Wire Staples Vs. Plastic Wire Staples - Electrical - DIY Chatroom Home Improvement Forum
Old 02-17-2009, 05:29 AM   #1
Rewards Points: 342
Question
Metal wire staples vs. Plastic wire staples
What are the advantages (and disadvantages) of Metal wire staples vs. Plastic wire staples and when and where do you use either one?
tripower is offline   Reply With Quote
Old 02-17-2009, 05:47 AM   #2
Remodeling Contractor
Both are used with Romex. But in many areas the plastic ones are the only ones allowed by local codes. NEC allows either. The idea is the plastic allows a buffer against romex sheathing and does not place as much pressure on the wire. With BX use the metal staples. might want to check local building department for what is code in your area.
Old 02-17-2009, 07:02 AM   #3
47_47's Avatar
Rewards Points: 50
Both are allowed in my area for romex. I use the metal ones 95% of the time (cheaper) and use the plastic ones in hard to get places.
47_47 is offline   Reply With Quote
Old 02-17-2009, 09:21 AM   #4
Rewards Points: 2,350
Plastic staples are used almost always the sign of a DIY. Pros almost invariable use metal staples.
Old 02-17-2009, 08:37 PM   #5
Rewards Points: 342
Question
You know I was getting ready to suggest just that. The electricians who did my addition used metal staples. But in every DIY book I have seen they use plastic staples. Do electricians look down on plastic staples? And what do you think about metal staples with metal staples with a rubberized coating on the heads?
Old 02-17-2009, 08:46 PM   #6
I wouldn't say look down, but you definitely know who did the job when you see plastic staples. It makes no difference as long as the job is done right. Same goes for the rubber coated staples, makes no difference.
Old 02-17-2009, 08:55 PM   #7
I've never even seen a plastic staple
Old 02-17-2009, 09:15 PM   #8
Me neither... heard of them but I haven't seen them around here (ON Canada), not in a home or on the shelf.
Reilley is offline   Reply With Quote
Old 02-18-2009, 05:09 AM   #9
I was talking about metal stables with the blue plastic insert. These are code in CT for romex.
Old 02-18-2009, 09:30 AM   #10
Ah, in that case I haven't seen a staple without the plastic insert (4 sale)
I thought they were required around here
Old 02-18-2009, 09:53 AM   #11
They are, but not everywhere. Use them in CO and now in CT.. But found out that in MD and DE they did not know they even existed.
Old 02-18-2009, 03:20 PM   #12
Never seen any plastic ones used out here in BC etiher......always metal, even for DIY stuff.
rovers1973 is offline   Reply With Quote
Old 02-18-2009, 03:48 PM   #13
I just checked, MA requires insulated staples on smaller then 8 awg, unless driven by a staple gun
Old 02-18-2009, 05:14 PM   #14
Rewards Points: 342
Here ya go:
http://www.idealindustries.com/produ...le_staples.jsp
Old 02-18-2009, 05:23 PM   #15
Electrician
You got a code reference in mind? They are not code in Connecticut I can tell you that.
Also, Bob is talking about Briscon Staples. Very common for New England.
chris75 is offline   Reply With Quote
Adding a wall switch to a pull chain fixture abacuslearns Electrical 17 12-20-2011 06:02 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
Wire size and type in Rigid Metal Conduit Al the Diy guy Electrical 5 02-05-2008 08:31 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 02:42 PM
Plastic vs metal switch boxes tropic home Electrical 1 11-29-2006 05:54 PM
