Metal Studs - Electrical - DIY Chatroom Home Improvement Forum
Old 02-23-2009, 03:20 PM   #1
metal studs
Can anyone tell me what type of boxes are to be used with metal studs,metal or plastic? won't the metal studs conduct electricity if there is a short?
Talman48 is offline   Reply With Quote
Old 02-23-2009, 03:27 PM   #2
If you are talking about non metalic cable applications, it's your choice.
Is this a trick question?
Metal does conduct.
220/221 is offline   Reply With Quote
Old 02-23-2009, 03:35 PM   #3
Custom Cabinet Maker
220/221 I think it is a trick question, did ya notice he didnt say if the power was on or not LOL LOL?
skymaster is offline   Reply With Quote
Old 02-23-2009, 05:47 PM   #4
Rewards Points: 150
Send a message via AIM to Bocolo
I usually don't know what I am talking about but he did say if there was a "short". Is it not the only time a short can occur is when the power is ON?
Bocolo is offline   Reply With Quote
Old 02-23-2009, 05:53 PM   #5
DAMN!!!!!!!!!!!! told ya it was a trick question ya got me
Old 02-23-2009, 05:54 PM   #6
No.
The short circuit exists even if de energized. There is stilll a path available.
The effects of the short only occur when the power is on.
Short refers to the distance traveled. The normal circuit goes from source to/thru the load and back to the source. If it somehow goes to ground before it completes it's intended journey, it's a short circuit.
Old 02-23-2009, 06:15 PM   #7
Rewards Points: 150
I guess it is a trick question. 220 as always is right. The short is present even when the power is off, you see the effects when the power is on. Would have never thought about that. Something else learned today. Thanks.
Metal Studs for Ceiling? fivecitydjs Remodeling 14 08-06-2009 01:32 PM
Pre-hung door with metal studs gmainolfi Building & Construction 4 02-07-2009 08:42 PM
metal or wood studs? pwise Carpentry 7 01-21-2009 11:08 AM
9 foot span ok for metal studs as ceiling joists? Garasaki Carpentry 7 08-22-2008 09:12 AM
How difficult is it to learn to use metal studs? YerDugliness Building & Construction 7 08-18-2008 06:59 PM
