Metal Sheeth Wire (extension Cord) - Electrical - DIY Chatroom Home Improvement Forum
Old 05-29-2012, 07:15 AM   #1
Metal Sheeth wire (extension cord)
I have approx 100 feet of metal sheeth wire (red/white/black/ground) that is buried in a pipe under ground from house to a shed.
There is nothing connected on either end.
What I would like to is put a plug inside of the shed. On the other end I would like to simply put a grounded male plug end so I can plug that into my GFI outdoor plug.
This will give me electricity in my shed (for a simple light, etc) But it also makes it simple if I want to disconnect.
Can you get a 3 prong male plug end that will allow me to hook up the red/white/black/ground to it?
fjacky is offline   Reply With Quote
Old 05-29-2012, 07:56 AM   #2
Your idea is completely illegal for many reasons.
My first question is what type of pipe is this cable in? Second, can you pull the cable out, will it move or is it stuck in the pipe?
Macro is offline   Reply With Quote
Old 05-29-2012, 07:59 AM   #3
Wire is in there pretty good, and its in 1/2" black flex pipe.
What are the illegal reasons?
Old 05-29-2012, 08:05 AM   #4
What type of pipe is it? Irrigation? Gas?
Too many to list. Just about every aspect of this installation would be wrong.
The wire.
The pipe.
The male cord end.
The lack of a proper feeder with OCPD.
The lack of a disconnect.
The lack of proper grounding (this is up in the air, depends on how much current you would be putting thru the illegal wire).
Etc.
I don't see any part of this installation that would actually be code compliant, lol.
Old 05-29-2012, 08:25 AM   #5
The wire.
The pipe.
The male cord end.
Etc.
Its basic irrigation pipe. The only thing I will be using out in shed will be a light and maybe a radio. I figured instead of having an extension cord laid out over the back yard grass, this would be just as good.
Old 05-29-2012, 08:28 AM   #6
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
You would have been better off running an extension cord underground (that that its legal either).
Old 05-29-2012, 08:32 AM   #7
It's a bad idea for all the reasons I mentioned and more.
That horrible, illegal, and unsafe installation can't be justified by comparison to the use of an extension cord.
Old 05-29-2012, 08:41 AM   #8
I'm not trying to justify it. The wire and pipe is already there and I figured instead of using an extension cord I would use the current piped wire as an extension cord instead.
Not trying to be rude, just wondering what the difference is. It's not a permanent solution...just a way to get a light out there when needed. Wouldn't the GFI plug trip if there was any issues?
Old 05-29-2012, 08:45 AM   #9
Code05's Avatar
Rewards Points: 1,104
1. What code cycle are you on or what is your location?
2 What is the burial depth of this cable?
3. Is this AC or MC cable?
Code05 is offline   Reply With Quote
Old 05-29-2012, 08:47 AM   #10
Code05's Avatar
The wire.
The pipe.
The male cord end.
Etc.
Actually depending on the questions I just asked, it could be done with a few modifications to the plan.
Old 05-29-2012, 08:52 AM   #11
As I mentioned, I am not seeing any part of his installation method that would be compliant.
He can't put a cord end on MC or AC. He can't feed the separate structure from a receptacle. He needs a disconnect in the garage. He may need a grounding system dependent on how he ends up feeding it, etc.
And that's all ignoring the fact that he has MC or AC buried in irrigation pipe.
Old 05-29-2012, 08:57 AM   #12
After I mentioned all the reasons why it was wrong, it seemed like you were trying to justify it by comparing it to using an extension cord.
There are a lot of shortcuts we can take. Some of them are against code, in your case it's almost all against code.
You haven't been rude. And I hope you haven't taken anything that I said as rude, because that was not my intent.
No, absolutely not. A GFCI will protect you in only a few instances, it's not an all-encompassing device that will protect you from everything. Breakers and proper, code complaint installation methods will be your best bet at protecting you and your family.
I'm eager to see what Code05 says, maybe there is something that I am missing. However, even if you can get away with using the current wiring, it will still require many changes to your plan.
Old 05-29-2012, 09:12 AM   #13
Code05's Avatar
If the OP in still on 2005 this can be done.
MC was allowed to be direct buried in 2005. The pipe is just a sleeve, does not have to be conduit.
If the depth is at least 12" and GFCI protection is provided at the house through hard wire connection, and we make this XX/3 a MWBC.
Disconnect can be a 2 pole switch and no GES is needed.
I said we would have to make modifications to the plan.
Old 05-29-2012, 09:28 AM   #14
k_buz's Avatar
There is a caveat to that tho, the MC would have to be listed to be direct buried and it would have to be impervious to moisture.
Old 05-29-2012, 09:34 AM   #15
As k_buz said, that buried MC idea is most likely not going to work.
Even if it did, you would have to change more of the plan than you would keep, which was my original point.
I'm wondering about something, can you sleeve direct burial cable in anything that you want?
2 wire to 3 wire plug on an extention cord. thomas herbert Electrical 3 04-19-2012 02:54 PM
shop light to switch to extension cord suthernkumfert Electrical 9 05-30-2010 08:07 PM
Metal wire staples vs. Plastic wire staples tripower Electrical 14 02-18-2009 06:23 PM
Air Compressor stopped working, extension cord was used. dawho1 Tools 3 10-07-2008 06:14 AM
Do I have a 30 amp or 70 amp welder. And help wireing it. Tmb9862 Electrical 17 12-04-2006 10:21 PM
