Old 01-01-2009, 11:23 AM   #1
metal or plastic box
im adding some outlets in my basement which has cinder block walls. is it preferable to use metal boxes and conduit or is there a reason to use plastic? i notice the existing two outlets in my basement used metal.
mharwell01 is offline   Reply With Quote
Old 01-01-2009, 11:43 AM   #2
J. V.'s Avatar
Are you finishing the basement? If you are just planning to mount the boxes to the block, you should use metal and use a piece of conduit to protect the cable. This is required. You do not have to run the conduit all the way back to the source.
Use concrete screws. Then if you want to finish it later they will come right down. Conduit too.
Plastic instead of metal... hvaclover Electrical 11 11-13-2008 10:07 AM
How do you remove plastic coupling nut and washer from braided metal connector? tony__s Plumbing 3 05-15-2008 11:15 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
Corner Bead....Metal or Plastic? yummy mummy Building & Construction 2 01-23-2008 06:11 PM
plastic or metal boxes for outlet wiring? yummy mummy Building & Construction 9 12-31-2006 02:37 PM
