Metal Outlet Box In Attic Space Grounding - Electrical - DIY Chatroom Home Improvement Forum
Old 11-02-2012, 04:21 PM   #1
Rewards Points: 640
Metal outlet box in attic space grounding
I have an unfinished attic space I am going to run a new leg to for an electical outlet in the attic... already have this setup to be an AFCI breaker since it is an attic space, 12 gauge wire on a 20 amp circuit to a single gang metal box.
Do you have to bond the ground wire to the metal box or is going to the outlet grounding screw only enough since it technically grounds the metal tabs you screw to the box also?
Any other code issues I might need to account for in adding a single outlet to an attic space?
thanks!
House Information: Build 1996, 1500 sq ft basement, 1500 sq ft 1st floor, 800 sq ft 2nd floor, 560 sq ft unfinished attic space on 2nd floor. Insulation: Attic blown fiberglass, walls R-19, Basement R-19. HVAC: Trane xc95m fully modulating furnace, single zone, Trane XL20i commiunicating AC unit, TCONT900 Communicating thermostat.
BlueBSH is offline   Reply With Quote
Old 11-02-2012, 04:32 PM   #2
Code05's Avatar
Rewards Points: 1,104
Metal box must be bonded by the grounding wire.
Code05 is offline   Reply With Quote
Old 11-02-2012, 04:36 PM   #3
Rewards Points: 640
just bond ground to the box or do a line to the box and the outlet ground? I got conflicting answers in the past on this with metal boxes
Old 11-02-2012, 05:30 PM   #4
Rewards Points: 80
The box and the receptacle must be grounded. All together.
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 09:49 PM
Need to know if my grounds and neutrals are connected right dorlow Electrical 185 01-15-2012 03:54 PM
Re: Installing Grounded Outlet in Metal Box srusten Electrical 3 12-08-2011 12:59 PM
Newbie questions on refinishing walkup attic with knee walls FileOpen Insulation 2 11-20-2011 12:31 AM
metal studs to build up attic floor Airborne180 Carpentry 6 12-13-2006 05:02 PM
