Old 05-18-2012, 08:24 AM   #1
Metal one gang receptacle box problem
The box is loose (recessing), and I can't keep the box forward enough to insert the receptacle (GFCI) and mount it to the box. I know about H-Clamps, but they keep the box from fall out of the wall. My problem is that the box moves back into the wall.
How to fix this?
Old 05-18-2012, 08:31 AM   #2
Post a picture and some more info.
Is it a reguler wood framed building, block walls, steel framing,
Is it drywall, plaster, paneling on the walls?
The box should have had two flanges, one at the top and one on the bottom to stop it from falling into the wall, is there no flange or has the material where they would sit been damaged?
Old 05-18-2012, 08:39 AM   #3
Electrical Contractor
rrolleston's Avatar
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
I have seen installs where someone removed the flange. If you can remove the box you could go with an old work box. Or maybe add a frange from another box.
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
OK To Bend A StrongTie Sheet Metal Hanger Connector? Gordo Burgess Building & Construction 5 10-12-2011 08:55 PM
Multi rib metal roof on double wide...static vents wpilotm Roofing/Siding 0 09-10-2011 04:51 PM
venting problem and metal roof nona Roofing/Siding 5 12-01-2010 08:26 AM
Spring Metal Weathestripping Problem Major Pane Building & Construction 2 09-24-2010 09:02 AM
Problen with hanging heavy draperies in sheetrock metal studs wall. Fixitgeorge Remodeling 1 04-11-2009 02:03 PM
