Metal Electrical Box; No Ground - Electrical - DIY Chatroom Home Improvement Forum
Old 03-31-2012, 03:07 PM   #1
Metal electrical box; no ground
Hi,
I am putting up this box for a GFCI. I am not sure if the angled screws at the top left and bottom right are for grounds. The location seems strange.
Is it ok to just put a new screw somewhere in the back of the box?
(I live in Alberta)
Thanks,
W
Wapmiasomey is offline   Reply With Quote
Old 03-31-2012, 03:22 PM   #2
Rewards Points: 6,652
What is the wire that you are using that appears to be cloth tape wrapped?
Old 03-31-2012, 03:29 PM   #3
Thanks gregzoll,
It's the old cable. I think it says Phillips 14/2 copper NMO-7. It's only got a hot/neutral/ bare ground.
The old covering just seems odd to me so I wrapped the last bit where it may rub on the box. It's all intact though.
Any comment on the ground screw?
Old 03-31-2012, 03:38 PM   #4
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Usually there is a spot you can add a green ground screw and pigtail. Not sure if you can use one of those angled screws for a ground or not.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 03-31-2012, 03:52 PM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
Since you are doing new work that box should have a clamp in the back to secure the cable.
Personally I would dump that box and get a larger plastic box. It is a squeeze to get a GFCI into that box. With plastic you just run the bare ground to the device green screw. They cost less than $2.00 (often less than $1.00).
BTW, you say it is old NM cable. The bare ground should be the same size as the insulated conductors. Old NM cable used to be made with an undersized ground and no longer code compliant.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 03-31-2012, 03:53 PM   #6
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
I could be wrong but if you have 14/2 with a ground if you hook the bare ground to the GFCI outlet there is no need to ground the box.
I think the box ground would be for old wire that did not have a ground in it.
sublime2 is offline   Reply With Quote
Old 03-31-2012, 03:55 PM   #7
Thanks rrolleston,
So it sounds like its ok to just drill in a new screw somewhere out of the way and attach the pigtail wire. Good. Im assuming the green screws aren't special. I'll use what I have laying around.
As well, I'm replacing 2 old 2 way light switches. The new ones have 3 terminals though (1 is for a ground). Do I need to pigtail the ground from the box onto the ground screw?
Is it ok to put 4 ground wires under 1 marret?
Thanks for the help fellows.
Old 03-31-2012, 04:02 PM   #8
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Originally Posted by Wapmiasomey
Thanks rrolleston,
To me it's overkill to attach the ground to the outlet/switch and to the box.
Unnecessary.
Use the plastic as suggested and your good to go.
No pig tails.
Old 03-31-2012, 04:16 PM   #9
Rewards Points: 330
Unnecessary.
No pig tails.
just so you know,any metal box by code needs to be grounded to the bare ground wire as well as outlet or switch.if the switch has provision for a ground.
oleguy74 is offline   Reply With Quote
The Following User Says Thank You to oleguy74 For This Useful Post:
k_buz (04-01-2012)
Old 03-31-2012, 04:22 PM   #10
Thanks for those comments. They're a great help.
The reason I have that box is that it's deeper and higher than a regular outlet (the wire clamp was just unscrewed). A guy professing to be an electrician i met said its code here in Alberta. I want to do the best job that I can.
Old 04-01-2012, 01:02 PM   #11
Rewards Points: 1,512
There is a hole in the back of the box right next to where the cable is shown coming in. Typical metal boxes of this kind have a clamp with a screw that goes into that hole (which clamp is missing from this box).
The ground wires from cables can be attached to the box not using the screw that holds the cable clamp at the back of the box (it's not tight enough when screwed down so as to not quite break the cable sheath).
The receptacle or switch can be bonded to the box without a pigtail to the ground wires when a clip for that purposes is slipped over the yoke end and squashed between the yoke and the box when the receptacle etc. is mounted in the box.
While a GFCI receptacle may "fit" the box using box fill calculations, it may be almost impossible to actually get a GFCI into the box pictured above depending on the number of wires and pigtails.
Why can't you connect Ground/Neutral bus bars on a sub secutanudu Electrical 42 11-07-2012 01:33 PM
50 Amps for a garage help IcyShadowz Electrical 48 05-31-2012 10:58 PM
How to install a metal fence post DEEP into the ground? boba7523 Building & Construction 14 09-20-2011 06:34 PM
Connecting new dishwasher and garbage disposal -- no ground wire in the conduits. arca Electrical 17 03-28-2011 02:06 AM
Ground rod or not? brotherman Electrical 30 07-15-2008 04:58 PM
