Metal Conduit In Wall? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-02-2011, 10:00 PM   #1
Metal Conduit in wall?
I'm putting a kitchen counter against an existing wall. It has 3/4" thick furring strips on a block wall. In order to run new wire behind the drywall can I run these thru metal conduit instead of building out the wall?
Strugglin is offline   Reply With Quote
Old 03-02-2011, 10:34 PM   #2
Licensed electrician
Rewards Points: 1,622
You can use conduit with the proper boxes.
You can also run your cables like in this thread.
1.5" deep wall can I use BX??
Old 03-03-2011, 07:32 PM   #3
one more question
Your dwg brings up one more question. I dug into the NEC code a little bit and I saw something in 300.4 (d). It appears to me that I might even be able to use NM cable(no conduit) fished in the wall, as long as I place the plates over the grooves in the strips and maintain the locations per your dwg. Is that possible?
Thanks for all the help.
Removing spine wall beko Building & Construction 12 02-02-2010 01:15 AM
how to determine if wall is load bearing Tonglebeak Building & Construction 26 01-20-2010 11:26 PM
Minimum wall thickness for electrical dc4nomore Electrical 10 10-10-2008 08:00 PM
How to Find Metal Telepost in Finished Wall bhumeny Building & Construction 6 02-29-2008 12:59 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
